Question about AMP (219560-5)
Wiring diagram for earthquake pa-4050 stereo car amp
I recently found a earthquake pa-4050c at a garage sale can some one help me with wiring instructions?
Please help me.....
i need diagram skema for use car amplifier 4 chanel mosfet p-450 planet audio
thank's a'lot before
me...
suryo.agustono@yahoo.com
Posted on Apr 27, 2009
I have the Earthquake manual in digital form. If you are still interested leave your email address and I'll get it to you.
Posted on Apr 29, 2009
  • mike Feb 02, 2013
    if you still have that manual please email it to me vangie4455@yahoo.com
Radio wiring diagram for a ford radio colors wire codes 1989 tempo
1989 Ford Tempo Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
found here.
Hope this helps
Ray
Mar 02, 2011 | Car Audio & Video
What kind of cables for Boston Speakers?
You want stranded wire, speaker wire, 14 - 12 gauge
Oct 07, 2009 | Boston Acoustics VR950 Main / Stereo...
Wiring problem
If you have an aftermarket stereo, the hook up is fairly simple. On your amp there should be a minimum of 5 terminals and an audio input. one is for remote which is connected to the blue wire on your stereo. Second is your ground which is your negative connection. it should be connected to the body of the car close to the frame. Third is your hotwire which is the positive lead, it should go straight to your battery. The fourth and fifth are speaker wires, you may have 2 or more of these that have + and - signs above or below them. When wiring the speakers make sure to match the positive and negative connections on the speakers. If your rewiring all of the door speakers to your new amp then the colors that you see once you have them out are the colors you route to the appropriate locations on your amp. If this is for a sub then you just the connect th positive terminal on the sub which is red to the + on the amp and the black terminal on the sub the the - location on the amp.
Lastley there should be an audio input that runs from your stereo to your amplifier. This wire should be ran as far away from the positive wire as possible to avoid engine noise coming through your speakers.
Jun 01, 2009 | Earthquake Sound XTREME 900W.5 Car Audio...
Dont know what i need to install this stuff
Hello bighollywood,
To install the head unit without cutting or tapping into the vehicle wiring, you'll need a "wiring harness". The Metra 70-1782 here seems to be the one for your '96 Prizm.
For the sub(s), you'll need an amp and a wiring kit. My recommendation would be the Alpine MRP-M1000. It's currently on sale at Crutchfield for $347. Shipping is included and you'll also get an "installation guide" to help with the wiring. The M1000 requires 4gauge power and ground.
Hope this helps.
May 17, 2009 | Earthquake Sound TREMOR XR12 Car Subwoofer
Need stereo wiring diagram
1998 Dodge Ram 1500 Truck Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amplifier Location: Behind the glove box.
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 30, 2008 | 1998 Dodge Ram 1500 4WD
Earthquake PA2050c car amp.
this company copied the v11 zeus amp @ one time , if its the same type of amp send pictures of the board to catally733@aol.com , i can help u out
Dec 11, 2008 | Car Audio & Video
Ford taurus
HERE IT IS. PLEASE RATE ME.
2004 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Stereo Antenna Trigger: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Nov 14, 2008 | 2000 Ford Taurus
Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Jun 19, 2007 | Panasonic CQ-C8303U CD Player
Computers & Internet Logo
733 people viewed this question
Top AMP Computers & Internet Experts
NOEL
NOEL
richie46
Tom Chichester
Are you an AMP Computer and Internet Expert? Answer questions, earn points and help others
