Question about HP iPAQ HX2490 Pocket PC
How to hard reset hx2490b
How to perform hard reset to my hx 2490b
Recovery Procedure for HP iPAQ hx2750, hx2490, and hx2790 Pocket PC Series:
To perform a Hard Reset on the iPAQ Pocket PC by pressing and holding the Calendar and iTask buttons (1 and 4).
2. While holding down the Calendar and iTask buttons, use the stylus to lightly press and hold the Reset button, which is located at the bottom of the iPAQ Pocket PC, for approximately two seconds.
3.. Release all buttons.
4.. Connect AC power to the iPAQ Pocket PC. The handheld Powers On,
performs the normal boot sequence, and automatically restarts system.
Posted on Jan 13, 2009
SOURCE:
Braeme HX OT2 open at start (fault 19) how to fix
says I should change the HX OT1 and HX OT2 switches and reset in service mode, however can't find where to get these
Jul 30, 2013 | Heating & Cooling
Hello, I formatted my external hard drive Samsung G2 HX-MU050DC and i lost the drivers. I can not find drivers. Can you help me please? Because i can no longer read the files that are on it. Thank you...
According to the microsoft site your external hard drive which is the Samsung G2 HX-MU050DC doesn't need any additional software it is automatically installed when connected..Maybe try to connect it to other USB port I preferred you connect it at the back of your CPU..If this doesn't work try to connect your external hard drive to other computer if it still doesn't work. sad to say but the problem is your external hard drive..
Jul 06, 2011 | Samsung G2 Portable External HX-MU050DC/...
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
HP iPAQ 2490B can not be hard reset
remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
Mar 07, 2009 | HP iPAQ HX2490 Pocket PC
When i do hard reset hx2490b screen calibration does not appear
Try using your finger to calibrate the screen at first. (If you have difficult to navigate to the alignment screen use the stylus & keyboard to feel out your way) when calibrated to an accepable degree use the stylus to calibrate the sreen, if the target doesn't respond to stylus at any specific piont use your finger. Continue this process till u get it aligned as best as possible. I suspect this problem is caused by specific points on the screen going bad.
Feb 24, 2009 | HP iPAQ HX2490 Pocket PC
HP 2490B SD CARD
check if your SD is SD HC because it cant read HC
Nov 04, 2008 | HP iPAQ HX2490 Pocket PC
Hx2490b
how to change the languge
Aug 20, 2008 | HP iPAQ HX2490 Pocket PC
Windows Mobile Device Center (Vista SP1 32bit) Can't sync with my IPAQ HX2490b
For the Samsung i760, disable "advanced network functionality" in the "USB to PC" setting by uncheckmarking it. Then Vista and WMDC will detect the i760 properly...
Apr 01, 2008 | HP iPAQ HX2490 Pocket PC
NO SOUND AFTER TOMTOM 6
I had the same issues as mentioned installing TomTom Navigator version 7 onto a HP IPAQ 2415 running Windows Mobile 5. As soon as TomTom was installed the sound stopped working.
I did a Hard Reset to restore the IPAQ which got the sound back. I then downloaded the trial version of WinCE Cab Manager http://www.ocpsoftware.com/products.php?nm=cecabmgr and used this to remove the files Btcoreif.dll and Btsdkce30.dll from the TomTom installation CAB. I saved the cab and then ran this again and it installed perfectly and I still had sound. Hope this offers a solution for anyone still having a problem.
Jan 13, 2008 | HP iPAQ HX2490 Pocket PC
HP iPAQ HX2490 Pocket PC Logo
4,221 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
