Question about Sony DAV-C450 System
Won't play cds
System won't play cd's, still plays dvd's fine but started cutting out when playing cd's a few days ago. I used a dvd laser lense cleaner and now it won't play cd's at all. It doesn't seem to recognize when a CD is inserted as it comes up with NO DISC when I try to play it.
  • 10 Answers
SOURCE: Sony DAV-C700 dvd player not responding
take it to a authorised technician and get the lens reading circuit replaced it will work
Posted on Jun 20, 2006
  • 3130 Answers
SOURCE: No disc message on DVD Player
What you might want to try before giving up would be to get a lens cleaning disc. If that does not work then you may have to take off the top, locate where the small laser lens is, and with a small cotton swab, soak slightly in alcohol, and in a swirling motion, clean the laser lens, now with the dry end, do the same. Wait a few minutes for all the residue to dry. Plug in the unit, and see if you made any differance. If you did GREAT!!. If not well at least you tryed, and there is not alot more you can do as a consumer, without test equipment, or speacial jigs. It most likly will not be worth taking into a repair shop, as these days these players are almost a dime a dozen!. Good Luck Ps Please do not forget to rate this.
Posted on Oct 16, 2006
SOURCE: dvd pauses
mY DAV-C770 has the exact same problem ...when watching a movie it will intermittently pause or freeze ...then continue. It will do this 20 or 30 times throughout a movie. I asked a tech at Sony for help and he told me the laser reader is out of alignment. The minimum amount to have the dvd player sent out and repaired is $200.00, and thats if it does not require any parts. with a new laser reader it will be about $400.00. Almost the same price as a new dream system. Not worth fixing. I used to think really highly of Sony - until now. Jackal
Posted on Jun 29, 2007
SOURCE: dvd always says no disc
i had this problem for copied dvds and cds and badley scratched ones when renting. never had the problem with genuine products. it seems to be able to dectect snide dvds but my 20 quid jobby in the bedroom will play them all !!!!!!
Posted on Nov 17, 2007
  • 16 Answers
SOURCE: movie freezes, skips.
Does sound like the laser. Realitically, not worth repairing. I'd say you'd be worth connecting a cheap DVD player to the system - then the Sony can carry on providing the surround sound audio and the new DVD player can provide the video. Then, if the cheap DVD player is still going, it can move to a bedroom TV if and when you replace the surround system....
Otherwise, I would imaging the speaker set (and even the non-working DVD player) on its own might fetch a reasonable price on an auction site - anyone who has a stolen DVD unit will probably be desparate for the speakers as Sony don't sell them separately!
Posted on Jan 15, 2008
SOURCE: DVD player does not play
Display of my DAV C450 does not work
Posted on May 11, 2008
0 characters
1 Points
I have a Zenith I played a dvd an it worked fine - put another movie in the dvd player and was going to watch that one and it never read - screen kept saying 'reading'. I tried another dvd and the...
try using a CD cleaner disk..
How old is the system?
DO CDs work when you try them?
Put a disk in... remembering the position it was in..
Then try to play the disk...
Eject if it does not play and look to see if it has moved to a different position...
If not, there is a motor problem or the laser is not sensing the disk being there.
Have you ever opened up the main box of the system?
Has anyone else been inside it?
If yes, then maybe it is time to do it again to observe if there is movement of the laser pickup..
Jun 01, 2011 | Zenith XBS444 250watt DVD/VHS 6-Speaker...
I have a (jvc dvd digital cinema system th-s3). that will not play original dvds however it seems to play copies and cds just fine in fact all other functions work correctly. i have tried a lens cleaning...
I have the same system. I've had no trouble until a year ago, then the system got particular about when it wanted to play DVDs. I've also used lens cleaner to no avail. It plays some DVD's but plays all CD's and some copies. It has given me good service but cost me a lot of money. I hope there is a simple solution to this.
May 17, 2011 | JVC TH-S3 System
HTS6500/37 will not read DVD' s led screen reads no disc, however system will play CD's
If it plays CDs but not DVDs then the Laser is failing and just a matter of time before it stops playing CDs also.
Apr 27, 2011 | Philips Home Theater Systems
DVD will not play or eject dvd/cd mode will not
Mp3 cd won't play it show {format unsupported} how can fix this problem?
Apr 18, 2011 | Bose 3·2·1 II System
Plays cds not dvds
This is is due the lense and motor section problem, to resolve this issue you need to replace the lense and motor set.
Feb 11, 2009 | Philips HTS-3555 System
Unabl to play dvd
hi angedembe, guess your dvd lens is dirty or worn out.try using a dvd lens cleaning disk this might solve your problem n if it still of no use then u have to change your dvd lens.hope the 1st method solve your problem.have a nice time..
May 11, 2008 | RCA 420Watt 5-Disc DVD/CD Progressive Scan...
DVD Will not play - CD Does Play
The laser is burned out. The laser is out of place. My bose has this problem.
Dec 18, 2007 | Bose 3 2 1 GSX System
DVD Problem
Call Bose and they will send you an update CD to update the firmware of the CD/DVD player. I had a problem where a few of my new movies would not play at all. They sent me an update, no more issues. If you're a registered owner, they will send update CDs frequently, be sure you're registered as well.
Nov 22, 2007 | Bose Lifestyle 38 System
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
DVD player not playing DVD's
Yes. The laser lens in your player is dirty or failing. To fix your problem, try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail stores.
Nov 30, 2005 | Samsung HT-DB120 System
Sony DAV-C450 System Logo
24 people viewed this question
Top Sony Home Theater Systems Experts
Dennis McCollum
Electro Med Services...
Are you a Sony Home Theater System Expert? Answer questions, earn points and help others
