Question about Electrical Supplies
Furnace shutting off
It keeps popping up the reset button up and i have to wait for the 45 sec. lock out time before it will let me push it down again so i can use the heat again.....why is this happening?
  • Frank
    Frank May 11, 2010
    what boiler are we talking about?
    make and model please
    Sergeant:
  • 359 Answers
IF THIS IS A OIL FIRED BOILER OR FURNACE IT IS NOT SEEING THE PROPER FLAME SO THIS IS A SAFETY CALL FURNACE TECH
Posted on Nov 08, 2008
How to unlock rca tablet
1. Turn your tablet off.
2. Hold volume up and power button at the same time.
3. Wait until the android dog screen pop up and then the android upside down with a triangle in it will come up the you hit reboot with your volume up or down button and press power for ok.
Mar 01, 2014 | Tablets & eReaders
How to repaire canon MP 510 error, wen turn printer on in the lcd diplay get message : error service required 5800
Welcome to Fixya.
Please try the following steps to resolve this problem - this same procedure worked for my colleague :
  • Power off printer
  • Hold down STOP/RESET button then Press and Hold down Power button
  • Keep Power button down and Release STOP/RESET button
  • Push STOP/RESET button twice
  • let go of power button
  • Wait 20-30 seconds - my display shows "canon Idle"
  • Then Push STOP/RESET button four times
  • Push Power button twice
  • Power off (shut printer down)
  • Wait for at least 5 seconds and power it back on
This should do the trick and will get you printing again in no time.
Thanks for using Fixya.
May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I changed the battery in my 2000 vw golf and now when I start it the flashers keep going off for about 2 minutes. Every time I start it. Pete
Easiest way is to reset the alarm/immobiliser,with the key unlock/hold over,windows will go down,wait 30 secs then lock car/hold key over,windows will go up,wait 30 secs then press/hold down 30 secs, remote unlock button,car is now reset,if you havent got a remote this may not work.....
Jan 03, 2011 | Volkswagen Golf Cars & Trucks
Lockout light flashing for 1/2 sec.
Press down and hold the reset button. You may need to bleed the oil line once you get oil in the tank.
Feb 23, 2010 | Honeywell Heating & Cooling
R7184b just got oil reset wont reset tried main furnace reset same thing green light still keeps flashing any ideas????
if the reset is a square button see if this will work. hold the button in, the green light will go out, count to 30 by 1000s, (1001-1002-1003 etc.) at around 1030 the green light should flash once. when it does release the reset and wait about 10 sec. the pump should start. if it runs for about 15 sec. and shuts off the pump needs to be bled. good luck, hope this helps.
Jan 17, 2010 | Heating & Cooling
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Electrical Supplies Logo
459 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
