Question about Microsoft Windows XP Home Edition
Network address problem
Comp requires network address how to enter address
    Novelist:
    Scholar:
  • 141 Answers
Could you explain what exactly you mean and/ if/ what kind of network your pc is hooked up to pls. Thanks....
Posted on Oct 30, 2008
How do I connect my home comp to my neighbors wifi
serch for the network in your network at Control Panel\Network and Internet\Manage Wireless Networks
now find the device name and enter password if required. you will be connected
May 06, 2014 | Microsoft Windows XP Professional
My comp.says network error,thomson tg585v8,i cant access my comp.
Check your network settings
Start, control panel, networking and sharing center. Click on your connection, properties. Click on TCP/IPv4 and TCP/IPv6 and click on properties. Make sure the settings say to obtain IP address automatically and also for DNS, then reboot the modem and computer.
You did not specify if you are using a router.
Jan 29, 2013 | RCA Thomson Digital Cable Modem (DCM305R)
How to obtain the ip address
make sure your device is set to DHCP, this is a network setting within your device. This will make it get the IP address from the router or network it is trying to negotiate with. If that network requires a Security key, often referred to as a WEP key, then you will have to enter that before the device can get an IP address.
Sep 21, 2011 | Sylvania G-Netbook
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
How do i find the network key? trying to get my niece's comp to work in my house with my modem
the network key is in the routers set-up utility
Open INTERNET EXPLORER and. In the URL address field, enter the IP address for your wireless router ( the DEFAULT GATEWAY. This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.do not type "www" just the number
Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" for user name and "PASSWORD" for passsword.
You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords (aka network key, wep key, passphrase).
Jan 03, 2011 | Belkin Computers & Internet
Connecting modem to WAN port then any lan port to computer provides no connection. straight from modem to comp is ok.
Make sure comp lan and wan are both activated, Make sure the ethernet cable from modem is plugged into the input slot and NOT 1,2,3,or 4
Then after all is connected, unplug main modem for 10 seconds, plug back in, then do the same with wireless router. 5 minutes later, you should be good to go.
You can access the software of you router by opening up an internet page, and type 192.168.1.1 and hit enter. It should bring you right straight to the router's firmware/software where you can change any settings if desired.
If it asks for username and password, the default is usually admin for both. (see owners manual to be exact)
Nov 16, 2009 | D-Link AirPlus DI-524 Wireless Router
I reset my modem and router now I cant make a wireless connection how do i check, troubleshoot router wnr2000
ckeck the ip address of the main server then ping the ip address(eg ping 10.0.0.5) if reply comes then your comp is connected to the network if not then assign ip address of ur comp in the same class of the network and try.
Oct 16, 2009 | Computers & Internet
Limited or no connectivity. No assign network Add. to comp.
Have you checked the cable?
Try this with a new cable installed:
Go to Start menu > Run > type "cmd" (without the quotes) and hit Enter or click OK.
In the black DOS-window type "ipconfig/release" (without the quotes) and press Enter.
Type "ipconfig/renew" (without the quotes)
and press Enter.
When the DOS windows displays an IP-number (e.g 192.168.1.2), close the DOS-window and try to connect.
Alternatively right click the network-connection icon down on the far right beside the clock and choose "Repair"
Apr 25, 2009 | Computers & Internet
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Microsoft Windows XP Home Edition Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
