Question about HP Officejet 5610 All-In-One InkJet Printer
Run Time Error When Installing
While I can print and fax, it says there is no devices when trying to scan. I attempted to re-install and I get a run time error and then it tells me that it cannot find the designated path. Can anyone help me? I am relatively computer dumb....
  • kurtzfamily Nov 01, 2008
    Ok. I did that, but I now get a Registry Key problem. Says Registry Mismatch. Anything?
    Novelist:
  • 183 Answers
First you need to go to Start --> Control Panel --> Add Remove Programms
Then Choose the Driver software for Printer and uninstall it.
Then go to this link :- http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=441125
Choose and Click on Operating system.
On next page click on HP Full Feature Software and Drivers
on Next Page click on Install and follow the instructions.
It will Install your printer software and resolve your issue.
Posted on Nov 01, 2008
Windows xp will not install my hp officejet 7310 all-in-one printer after i uninstallit? i keep getting a 1603 error or can't remove the old webreg?
If problems arise while installing or uninstalling the software, download this removal utility to uninstall the HP All-in-One software before attempting software reinstallation. IMPORTANT NOTE:
This utility removes only version 4.2.0 of the driver.
Running the removal utility may remove the drivers and software for other HP printing, scanning or digital imaging products.
This utility works in stages. The first time the utility is used, it runs at level one. The next time the utility is used, it runs at level two. There are four levels. The effects of each level are shown in the table below.
Uninstaller level Description 1 Removes the Windows device discovery (Plug and Play) entries from the Windows registry. After running level 1, connect the USB cable to the all-in-one and let Windows try to discover the device again. 2 Performs Level 1 and removes the software drivers. After running level 2, run the all-in-one installer and use the "Add a new device" option to attempt to reinstall the all-in-one again. 3 Performs Levels 1 and 2 and removes the HP Photo and Imaging software. You must completely reinstall the all-in-one software after running level 3. 4 Performs Levels 1, 2 and 3, and removes HP Software Update. You must completely reinstall the all-in-one software after running level 4. Installation instructions:
  1. Click the Download now button.
  2. When prompted, choose Open or Run to start the download and run the installer.
  3. Follow the onscreen instructions.
Details and specifications File name: s.gif gr_uninst.exe [1/1, 866.52k] Released: s.gif 2005-01-11 Version: s.gif 4.2.1 Compatibility: s.gif Microsoft Windows XP, Microsoft Windows 2000
Dec 20, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Can't get my HP j4680 to Fax or Scan. I have spent many hours today trying to set up thi HP All in One. I finally have the printer working on my wireless network. When I tried to set up the fax, I got...
Hi Jelind
This is the first thing to do to clear all the printer history. Go to the bottom of the thread.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Unable-to-install-HP8500-drivers/m-p/17...
This is the second thing to do after you try to install and it tells you a section is missing from INF. There is probably a missing registery value for imaging device. It fixed my 309a issues. Great hardware-support a bit lacking.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035977&cc=us&dlc=en&lc=en&jumpid=reg_R1002_US...
sharpinjr
Apr 18, 2010 | HP LaserJet P3005 Printer
How to get my printer to print
It may or may not work, but try installing as Administrator and setting the program's EXE into "Compatability Mode for XP SP2",and also, running as Administrator. Windows 7 just doesn't want to support any hardware over like a year old... Drivers are a HUGE issue. Especially for older stuff. Compatability Mode is one way round it but not always.
Also try installing in SAFE MODE if all else fails, still set Comp mode & run as Admin tho.
Jan 31, 2010 | Brother MFC-210 All-In-1 Print/...
Scanning problem
You will need to run the setup disk. Atypically HP install utilities will run installing one facet of the machine at a time. i.e printer, scanner, fax.
Rerun the utilities disk and follow the directions you should be fine.
Aug 14, 2009 | HP PSC 2410 All-In-One InkJet Printer
Print cartridge prob [tri-color] refer to ... doc to troubleshoot
HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
Normal catridges recommened by HP are given below :
01. HP 901 - Black which will print 200 Pages.
02. HP 901 - Tri Colour which will print 200 Pages.
03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
This printer is most rugged one used by Home as well as in offices.
The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
  • Print, copy, scan and fax with a single machine
  • Print fast, at up to 28 pages/minute black, 22 color##
  • Fax at speeds up to 33.6kpbs
  • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
  • Preserve important documents for decades without fading1
Solution:
Please use the originai catridges for this printer and there will not be any issues.
In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
Jul 21, 2009 | HP Officejet J4680 InkJet Printer
LexmarkX5495 won't scan....can you help?
go to www.isohunt.com and download driver detective with key. Install driver detective. And let it to search for the drivers your system needs to operate any hardware. When it searches the drivers for your MFP then install it.
cheers
Dec 07, 2008 | Lexmark X5495 Printer
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
I would like to use my epson stylus cx7800 to receive and send fax's. Can this be done. Please explain and instruct. Thanks. lstrat@telusplanet.net
If you are running Windows, and have a modem, you can use the Windows Fax Services which are built in.
You may not have it installed, as it's an optional component. Go to Control Pane/Add Remove programs. Select Windows Components on the left hand side. If Fax services is not checked, do so, and press OK. You may need your original Windows install CD to complete the task.
If you still need help with this, please respond to this message. If I have solved your problem, I would appreciate you rating this as "solved".
Good Luck
airoff
Jul 21, 2008 | Computers & Internet
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
