Question about D-Link DP 301U (DP-301U) Print Server
Ip adress missing
My ip adress missing after i press the rest button at the print server. how can i get it?
  • Jannette Amandy May 11, 2010
    How is your printserver connected to the network? Do you have a router?
If you have server, you can find it in DHCP
Posted on Dec 01, 2008
Need to find out the IP adress of a HP laserjet P2014n Is there a button I can press on the printer to give me those details
Open the embedded Web server To open the embedded Web server, type the IP address or hostname of the printer in the address field of a supported Web browser. To find the IP address, print a Configuration page at the printer by pressing and holding the Go button.
Sep 22, 2011 | HP LaserJet P2014 Printer
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
ZEbra 105SL. How can I install it on a printer server? Which port should I use when asked for in "create new port" option using the add printer wizard?
external printserver? on the printer is PARALEL PORT, press withe button from the printserver to print net config. label, then go to create new port, write the IP adress...
Sep 14, 2010 | Zebra 105SL Thermal Label Printer
How do you fin the IP adress on the printer?
What model of printer is it?
if it has a built in print server then you can normally go through the printer menu and set/view the IP Address. If it has a stand alone print server there is normally a button on it then you can press and hold this will then print out a page on the printer showing you information on the print server including its IP
Jan 16, 2010 | Dell 948 All-In-One InkJet Printer
My network HP laserjet 4Vprinter and ESI 2830 pocket print server suddenly gives an error message "No RARP/BootP Server". How can I fix this?
the information in the link is too long to paste but you may want to look at it.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - TCP/IP, Messages on Configuration Page or Self-Test Page
Get the IP address subnet and gateway address of a computer in the same network.
Usingthe LJ5's control panel, setup a static IP for the Jet Direct using thenumbers you got from the Laptop, except change the last number of theIP to one that is not being currently being used. Perhaps adding 5 or10 to the highest number in use.
Here are the steps to configure the LJ5.
1.Press MENU, repeatedly, until the following message appears on thecontrol panel: HP LaserJet 5/5n/5m and the original Color LaserJet: HPMIO MENU
2. Press ITEM. CFG NETWORK=NO* will appear.
3. Press the PLUS button once. CFG NETWORK=YES* will appear.
4. Press ENTER or SELECT.
5. Press ITEM repeatedly until CFG TCP/IP=NO* appears.
6. Press the PLUS button. CFG TCP/IP=YES* will appear.
7. Press ENTER or SELECT.
8. Press ITEM until BOOTP=YES* appears.
9. Press the PLUS button. BOOTP=NO will appear.
o When using BootP or DHCP, keep the setting BOOTP=YES*.
o The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect.
o No other TCP/IP configuring is necessary.
10. Press ENTER or SELECT.
11. Press ITEM. IP BYTE 1 = (value) will appear.
12.Press the PLUS button until the value of the first byte of the IPaddress appears on the control-panel display. By pressing SHIFT and thePLUS button, the value will decrease.
13. Press ENTER or SELECT.
14. Press ITEM to continue. Repeat Steps 11-13 to configure the remaining bytes of the IP address.
15.Repeat Steps 11-13 to configure the subnet mask bytes (SM BYTE 1=),syslog server IP address (LG BYTE 1=), default gateway (GW BYTE 1=),and timeout (TIMEOUT=).
16. Press ONLINE. Print a self-test page to verify the IP settings.
17. If the test page does not show the correct settings, power cycle the printer and reprint the test page.
else: have the printserver reinstalled
www.nls.com/common/pdfs/v307n10.pdf
Nov 24, 2009 | Extended Systems Pocket Print Server
Avaya assighning New static IP address after IP address conflict
The phone is looking for the calsrv ip address, which it cant see. So it is trying to "Dsicover" it.
Go to another phone and press "mute"ADDR#
You can then see the ip address information and input it into the phone that is incorrect.
Mar 04, 2009 | Avaya 5610 IP Phone
Old IP address
You can reset the MarkNet X2000 to factory defaults - which includes resetting the IP address to 0.0.0.0 like this:
1. Press and hold the Test button until all four lights stay lit simultaneously, then release the Test button.
2. When #3 and #4 lights light simultaneously, press and release #1 (the Menu button).
3. When #3 lights press and release #1 (the Menu button).
4. At this point the X2000 print server has been restored to the factory default settings and should have an IP address of 0.0.0.0.
-John
Feb 06, 2008 | Lexmark Refurbished MARKNET X2000 SERIES...
IP address for Copystar CS-3035
1.On the drivers CD You must have Quick Config tool.Just click on setup Icon and follow directions.
2.Or just press "printer"Button on the operation panel of machine.Go to Interface-TCP/IP and You will see IP adress.
You can also from printer menu select "print Status Page" and page will be printed.You can find IP adress on the status page.
Nov 26, 2007 | Office Equipment & Supplies
Emulex NetQue Pro2 Print Server how do I connect to it
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
D-Link DP 301U (DP-301U) Print Server Logo
125 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
