Question about Epson Stylus Photo R220 InkJet Printer
Cant detect ink!!!!
Hello there, i have c90 here i try to unclog it but after i've done unclogging it does not detect my ciss..
does anyone to solve it?
    Genius:
  • 1,447 Answers
Hi
There is a problem with the sensor on the printer, try using an ink cartridge just for troubleshooting purposes, if everything fails. have it service or buy a new printer instead.
Hope this helps
Posted on Oct 30, 2008
Why won't it print or scan?
How To Unclog Brother Multifunction Inkjet Printhead Nozzles
www.inkmagic.com/shopcontent.asp?type=Unclog...Inkjet_Printhead...
Many Suggestions and Directions to Unclog you Brother Multifunction Inkjet ...problem when a new cartridge is put in, your Brother printer will do a priming. ... So, before you blame the compatible cartridges for your Brother printer not printingproperly, ... Many companies want you to believe that "one ink does all printers".
How to Unclog Epson Printhead Nozzles - - InkMagic ...
www.inkmagic.com/epson_clogged_printhead.htm
Clogged nozzles - Epson printers Epson printers have a built-in, permanent printhead.... To overcome this problem when a new cartridge is put in, your Epson printer ... If you manage to get all nozzles printing after 6, 8, 10 or more cleanings your ...InkMagic International remanufactured 2,000 - 4,000 HP inkjet cartridges a ...
All-In-One Printer Fails To Print Black Ink? - Super User
Jan 05, 2016 | Epson Inkjet Multifunction Machines;...
Epson 1900 inket print head clogged
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 07, 2010 | Epson Stylus Photo R1900 InkJet Printer
How can I unclog the ink head I have cleaned it numerous times?
To unclog an ink head you need to dampen a small section of a paper towel and then run the ink cartridge over the dampen part of the towel to the dry part. If this dosn't work you will need to purge the ink cartridge. This is usaly done in the printer itself. You need to go to the printer software and in it you need to choose "Clean print head" option . Some printers has this option and some do not. The true way to fix this is to replace the cartridge.
Good Luck
Nov 11, 2009 | Epson Stylus C86 InkJet Printer
How can you clean the printer but clicking on
Hi
If yourPSC 1210v printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your HP 56 57 still has ink? Empty they are about 30g Each 1g over that is 1ml of unused ink.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a littleMagic Inkjet Flush to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Nov 02, 2009 | HP PSC 1210v All-In-One InkJet Printer
I hooked up my HP Deskjet 812C seems like there is no power?
HTML clipboardHi,
It may sound silly but have you had your printer unused for a while?
If so the inks C6615A [No. 15] black and C1823A color ink cartridge may have clogged up?
The empty weights are 65g and 90g anything over that...
1g = 1ml of unused ink
If you still have ink you can unclog them with a HTML clipboard Magic Inkjet Flush Kit which is great if you ever need to UNCLOG an HP Canon Epson or any other inkjet printer.
Good Luck!
Tinteiros (Ebay)
Oct 29, 2009 | HP DeskJet 812c InkJet Printer
Print head clog and I use half my ink unclogging them
Thanks for using FixYa!
There is indeed another way to unclog your print head without wasting ink. All you need to do is to take out the cartridge then get some alcohol (not liquor but the antiseptic type like ethyl or isopropyl used for treating wounds or cleaning stuff) drop around 3 drops of alcohol into the ink inlet and leave it overnight. This should declog and clean the print head. I hope this helps because it did work for me.
Have a nice day.
- HotRatchet
Aug 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Red ink nozzle on a brother mfc-240c is clogged
I found an article on how to unclog Brother inkjet nozzles on the InkMagic website. It worked for me.
http://www.inkmagic.com/Articles/Unclog%20nozzles%20on%20your%20Brother%20multifunction%20inkjet%20printer.htm
I'm also using their ink now. I'm a photographer so colour is really important to me. InkMagic ink is as close to the orginal Brother ink as I've found. The MFC-240 cartridges are here:
http://www.inkmagic.com/shopping/shopdisplayproducts.asp?id=1133&cat=Brother+MFC+240c
Hope this helps ... Dale
Apr 01, 2009 | Brother Multi-Function Center MFC-240C...
Error massage not compatible ink cartrage when using ciss supply
Solution?the solution is never to buy an epson printer ever again! i bought mine early last year with the CISS and since then have give me that same red lights problems like .. forever ! the solution is to sort of take off the carttridge and put it back again. u might have to do this a few times before it actually work . and oh yeah , you have to print everday with epson cause otherwise the ink will clog !! mine is already clog, i have to buy the original ink now to unclog it but still it produce lines! Since then i have give up hope and put my epson in the box to end my misery . i;m using Canon Pixma MP142 with CISS and till now no problem !!
Jan 02, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
121 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
