Question about Sharp CD-C460 Shelf System
Have no sound on front and rear speakers...
My cd-c460 suddenly have no sound on rear and front speakers... the central speaker still has sound, but i can feel that the volume on central speaker vary a bit... tried to reset it, pressing (vol down + FF>> + power button), but it still doesnt work properly. Switched to Dolby pro logic phantom mode, still has no sound... switched back to Normal Mode, sound only on central speaker. switched to bypass mode. Up the volume to 10, there are sounds, but very very low on front speakers. Any clue what happened? maybe some component gone bad... the system is very old :P thanks
Looking at the front of the unit take the left side pannel and replace the fuses. ive had to do that with mine several times because of the same problem
Posted on Mar 02, 2008
My levono C460 system sound is off so no sound what can i do?
Hi
3 possible solutions:-
• Adjust the Windows volume control - select the speaker icon from the Settings Charm or click the arrow on taskbar to show the hidden icons in Windows desktop mode, then click the speaker icon. Ensure that the volume is turned up and the sound is not muted. Adjust the volume, bass, or treble controls to eliminate distortion.
• Reinstall the audio driver.
• Disconnect any headphones from the headphone connector - sound from the speakers is automatically disabled when headphones are connected to the computer's side-panel headphone connector.
I also give a link below to a page from which you can download the full manual for future reference.
Desktops and all in ones Lenovo Series all in ones Lenovo C460 All in One...
Cheers
Oct 26, 2014 | Computers & Internet
Problem with sound card AMD870 . I have configured 5.1 sound system and it works but suddenly it dissapears ... I mean disapears only center/ subs and rear speakers while front is still working....
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 24, 2011 | Asrock ASUS M4A87TD EVO AM3 AMD 870 SATA...
I have bought a Sony Home theatre with total 6 speakers (including woofer, rear speakers (2), Front speakers with stand(2) and onr central speaker. But the centre speaker is not responding during TV,...
That would all be a function of your HTS, not necessarily the speakers.
Get a handle on how IT works, maybe find the manual and perform setup to verify the speakers work at proper levels.
I imagine it has several Digital Sound Processing modes that can create multi-speaker sound from any source.
http://www.retrevo.com/support/Sony-SS-CN550H-Speakers-manual/id/752ci570/t/2/
Feb 14, 2011 | Sony SS-CN550H Center Speaker
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
No sound, cenral and rear speakers Dell 5650 speakers
the surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Jan 20, 2009 | Dell 5650 Computer Speakers
Rear speakers skreech
i guess there might be a wear on the cone
Nov 14, 2008 | Car Audio & Video
Front speakers have no sound now.
Hups, apparently my friend put the speakers into wrong slots. Then i just copied him while trying different speaker setups and it simply never occurred to either of us to check if these were the correct slots :-D
Anyway sorry for these useless posts.
May 05, 2008 | Yamaha HTR-5830 Receiver
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Sharp CD-C460 Shelf System Logo
309 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
