Question about Gigabyte GA-945GCM-s2C socket LGA775 motherboard (4719331834135)
Wont boot i tried to upgrade the bios from p3 to p5 following the users manual and it displays the process was succesful, but after re-booting theres no display anymore and wont boot.pls any help from this
  • antimatrix12 Dec 10, 2008
    same problem omg please help...
No VGA Drivers our mother board
Posted on Oct 30, 2008
Toshiba tecra p5 up on black Screen on PCI EXPRESS ERROR can't boot????
If you can't boot to the bios, you are in major trouble. You can try and see if the manufacturer has a bios flash program you can load on a Flash drive to flash the bios...you will have to research that on another computer, obviously.
Nov 25, 2014 | Toshiba Computers & Internet
Tip
FLASHING BIOS - THE PROCEDURE
BIOS Update Procedure
All latest Motherboards today,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With
FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about
this.
Please read the following instructions in full before starting a Flash BIOS upgrade:
A. Create a Bootable Floppy (in DOS)
•With a non-formatted disk, type the following:
format a:/s
•If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you
are flashing the new BIOS.
B. Download the BIOS file
•Download the correct BIOS file by clicking on
the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip from www.winzip.com or www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•You should have extracted two files:
Flash BIOS utility eg: flash7265.exe (for example)
BIOS eg: 6152J900.bin (example)
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file). This information is usually provided.
C. Upgrade the System BIOS
During boot up, write down the old BIOS version because you will need to use it for the BIOS backup file name.Place the bootable floppy disk containing the BIOS file and the Flash Utility in drive a, and reboot the system in MS-DOS, preferably Version 6.22
•At the A:> prompt, type the corresponding Flash
BIOS utility and the BIOS file with its extension.
For example:
flash625 615j900.bin
•From the Flash Memory Writer menu, select "Y" to
"Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE:
eg: a:\613J900.bin
Alternatively select "N" if you don't want to save your current BIOS. Beware, though, that you won't be able to recover from a possible failure.
•Select "Y" to "Are you sure to program?"
•Wait until it displays "Message: Power Off or
Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete theprocedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
Make sure the new BIOS version has been loaded properly by taking note of the BIOS identifier as the system is rebooting.
For AMI BIOS
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips
Note:
1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to.
(This option is not available when flashing an AMI BIOS).
2. If you have problems installing your new BIOS please check the following:
Have you done a clean boot?
In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a
BIOS.If you have not used a bootable floppy, insure a clean boot either
a) pressing F5 during bootup
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by
using the EDIT command.
Have you booted up under DOS?
Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers.
Important:
Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above
procedure (format a: /s and rebooting from a:\).Have you entered the full file name of the flash utility and the BIOS plus its extension?
Do not forget that often you will need to add a drive letter (a:\) before flashing the BIOS.
Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c:\ your will need to type
a:\615j900.bin, rather than 615j900.bin only.
on Dec 30, 2009 | Computers & Internet
Tip
BIOS Update Procedure...
All latest Motherboards today, 486/ pentium/ Pentium Pro etc., ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about this.
* With a non-formatted disk, type the following:
format a:/s
*If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you are flashing the New BIOS.
* Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
* Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the Winzip for windows shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD Roms found in computer magazines, have a shareware version of winzip on them.
* You should have extracted two files:
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file. This information is usually provided.
C. Upgrade the System BIOS,
Place the bootab le floppy disk containing the BIOS file and the flash utility in drive a, and reboot the system in MS-DOS, preferably version 6.22.
* At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
* From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" If you want to save (back up) your current BIOS (strong recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:\613J900.bin
* Select "Y" to "Are you sure to program?"
* Wait until it displays "Message: Power Off or Reset the system"
Once he BIOS has been succesfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not able to boo, and you will not be given another chance to flash. in this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
For AMI BIOS
Once the BIOS has been successfully leaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips
Note:
1. Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
In other words, did you the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
If you have not used a bootable floppy, insure a clean boot either by
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by using the EDIT command.
Booting in windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers.
Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the abovr procedure (format a: /s and rebooting from a:\).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:\) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c:\ your will need to type a:\615j900.bin, rather tham 615j900.bin only.
on Dec 26, 2009 | Computers & Internet
PC RUN normal: the configuration BIOS STOP and message is: configuration is ok! Problem upgrade failed! use F1 for setup continue or F2 for chancer manual setting DATE/TIME.Thank you.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 08, 2011 | Computers & Internet
Actual problem is that i forgot my windows xp login password. how can i solve my problem? and another problem is that when ever i inserted any bootable cd in cd-rom it displayed compaq logo only. how...
During the boot up process you will see on the screen press delete to enter set up
Press delete during the boot up process to enter BIOS scroll down to set user password or administrator password you can change or remove your password from there
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Oct 26, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
Z4MPLUS P3/P5 ERROR I found some problem in Zebra Z4m plus printer like error p3/p5.please give me solution for that
The display shows P3/P5 ERROR? You can try to load firmware, download the file from www.zebra.com press the keys - and +, turn the printer and you see FIRMWARE DOWNLOAD in screen, download the file through the parallel port.
Roberto Martinez
Jun 01, 2009 | Zebra Z4Mplus Label Printer
XWT-RC061 SATA card used for DVD rewriter wants to boot computer.
from the manual
Note: there are 2 sata drive ports and 1 esata port named P1 to P3. (P1 and P2 are internal) Chaning the jumper setting allows you to select between external and internal ports to use.
Both underside --> P1 and P@ are working
Both topside --> P2 and P3 are working
hope that helps...
Jan 24, 2009 | Fanner (XWT-RC061) ATA Controller
Error message says cant find operating system
Are you intending on reinstalling windows? If so follow these steps;
YOU WILL LOSE ALL YOUR DATA IF YOU FOLLOW MY METHOD
Enter your BIOS menu - This is generally accessed by tapping F1 or Del when the computer is booting, but it should be displayed on the screen as the computer starts
Find the "Boot Options" menu sometimes it can be a tab or under advanced options each BIOS varies
Set you 1st boot device to CD/DVD
Reboot with the disk in drive
You should be prompted to hit any key to boot from CD - Do so
The CD will begin the installation process
Delete your current partition and reformat the hard drive in the format of your choice then begin the installation process
It is pretty simple from there
I DO NOT advise doing this is you are not confident with your abilities it may be a job for your local technician.
Blazamane
Jan 07, 2009 | HP Pavilion 6745C (P1442A) PC Desktop
Installation stops
Jonags,
NTLDR is the NT Loader basically the instructions the bios needs to start your Operating system.
If it is not finding the NTLDR it could be due to a couple of things.
First thing I'd do is to check that the install disc is a full install disc for the OS and not an Upgrade disc.
If it IS a full OS disc then we need to enter the BIOS (Basic Input Output System) Usually done by hitting <Delete> or <F12> during boot up. Once in the BIOS there should be an option for "Boot order" we need to set it so that your optical drive (CD/DVD) is listed as the 1st entry in the boot order. press <F10> to save and exit. Put the CD/DVD in your drive and boot up your computer.
this should get you started with your installation.
If it does not, you likely have a faulty optical drive.
Please post your results so we can further assist you.
Thanks
Dave
Nov 09, 2008 | Compaq Creative Sound Blaster PCI 128...
Gigabyte GA-945GCM-s2C socket LGA775 motherboard (4719331834135) Logo
148 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
