Question about Cnet CNP 410S (CNP410S) Print Server
I have tried both the slingle usb print server and the parallel print server on a canon image runner 1630, the software finds the print server and i give it an address to match my local lan. i send a print...and nothing happens. it is frustrating, any suggestions???!!!
0 characters
1 Points
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Error Code #E000602-003
0003 A sector fault is detected on the HDD.
You need to replace HDD, upload system, language,...
Call service, beacause all of above is done over service support tool.
Jun 30, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Transferring stored information to p.c.
If you do not have send function, you need scangear software.
From canon download site you can find software and manual.
Feb 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Error code E000514-0000
I researched the solution for error code E000602-0003: Your hard drive is going bad. Using the DSK CHK utility (1&9 while powering up) may fix the bad sector and get rid of the error by trying HD clear & then HD check for every sector in service mode , but more likely than not, the error will come back. You can try to upgrade the system software as well. If nothing works, you need to get the HDD replaced. This problem happens alot in these models. Hope this helps.
Jan 20, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Help I can't get a Word doc to print on 11x17 on my canon Image runner 2200
guessing its the wrong print driver go to imagerunner ,com and look for different driver
Oct 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Installing network card in canon image runner 2200
k you need the network card the boot rom N chip then you need to flash the copier using the canon system software . just putting in the network card wont make it print Sorry
Aug 07, 2008 | Print Servers
Cnet CNP 410S (CNP410S) Print Server Logo
35 people viewed this question
Top Cnet Print Servers Experts
old marine
old marine
Are you a Cnet Print Server Expert? Answer questions, earn points and help others
