Question about JVC HD-52G786 52" Rear Projection HDTV
Optical Audio Output
I tried the Optical Out and plugged into my reciever Optical Input. No audio/sound?
I notice that on all my other A/V devices (DVD, PS3) that the Optical output is illuminated and therefore when you plug the cable in you see the light coming out of the other end. There is no such light coming from the TV's output.
Leads me to beleive that this has never worked. I can bypass it by plugging each individual player into the reciever but i'de rather just run the output from the TV to the reciever for all.
Any ideas?
  • Guntr Jan 27, 2009
    I have the EXACT same issue with my JVC HD-56FC97.
SOURCE: Optical audio not working
i have this problem but i dont have a cable box, if i use rca's i get sound but optical cable nothing
Posted on Oct 08, 2007
SOURCE: HDMI input
The green screen is caused by light hitting the back of the tv. Either move the tv to a location where direct sunlight will not hit it or put up strong curtains. As for fixing the problem, do a search for JVC green screen reset on AVS Forum, its easy to do just dont have the info with me now. Keep in mind if direct sunlight hits the back of the tv it will do it again. I have put up some good curtians and ensure not to open them when watching the tv. Hope this helps. I am Hayward, have a nice day.
Posted on Feb 20, 2008
SOURCE: Power issue, clicking noise, turns off
The clicking is the power on relay closing and opening. This happens because the TV has several built in safety systems that will detect and over voltage and over current load situation.The power supply starts up for an instant, senses and overload of either or both kinds and then the safety switches trigger a cutoff. When this happens the power supply will not start up again because another circuit called a latch keeps it disabled. By unplugging the AC cord and trying to start it again releases the latch until the failure triggers it again.
On these TVs the power supply is rarely the cause of the shutdown. Something further down inside the TV has failed. Replacing just the power supply will not fix the problem. The most common reason there would be an overload would be in the high voltage circuit that lights up the 3 CRTs, next would be the coils around the CRTs that bend the beams to make the picture. This is normal circuit aging and wearing out. Unless you are very skilled with trouble shooting TVs I would recommend having a service center look at it. An authorized JVC shop would be your best choice because they will have access to the manuals and bulletins and have probably had other similar JVC units thru their shops.
Posted on May 17, 2008
  • 133 Answers
SOURCE: My tv screen is green
there is a code to reset the HDMI video, i think it is--hit Display on the remote, then sleep timer and video statice at the same time, then the number 2, then turn the tv off, after it shuts down all the way, turn it back on, should take care of it
Posted on Jan 09, 2009
  • 864 Answers
SOURCE: no owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Posted on Jun 02, 2009
Optical inputs
You have to re route the sound from the samsung to the optical output. You do this is the audio setup section of the setup menu.
Jan 23, 2014 | Pioneer VSX-D498 Receiver
Ok so the issue is that after i have ran a hdmi cable from reciever to monitor, and 2 hdmi inputs (dvd and video2) into the reciever where im running a ps3 into the video2 port and foxtel/satellite tuner...
Try this, although recivers have video pass through, it is not the best option for video to your monitor. Depending on what you have for input/output on your TV/monitor, and, if you can, you should run all your video components directly to TV via(best)HDMI(video and sound) or, component and digital optical(best) or RCA, Then run digital optical out from you TV out to receiver in. You can use your monitors menu to chosse what you view and only have the onr input to you reciever. ASll you have to do then is go through you recievers menu to get the audio. Less connections less hassle. In other words, you would run your sat tuner to tv inputsat or cable, then dvd to dvd, PS3 to video 1 etc., on TV/monitor, then the single audio output to reciever.
Dave
Jul 03, 2011 | Audio Players & Recorders
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
I used an optical cable from my ps3 to my receiver but no sound
change the sound output to 'optical' on your ps3
system menu
Sound
Sound output
(select optical)
I think you may have to change the channel on your AV reciever to Input or audio or something
Jul 08, 2009 | Audio Players & Recorders
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Dec 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
JVC HD-52G786 52" Rear Projection HDTV Logo
264 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
