Question about Brother Lay-In Thread Serger Mechanical Sewing Machine
Brother Serger 634d
Love my serger but i want to do the rolled hem stitch. i don't have the foot or needle plate since i bought used and no one can find the parts i need. Any suggestions?
  • 1 more comment
  • VPARADISV Nov 22, 2008
    PURCHSED USED SERGER 634dD
    NEED ATTACHMENT FOR ROLLED HEMMING
  • Anonymous Mar 14, 2014
    I am trying to make a rolled hem but without the special foot. It can be done, I've seen it on youtube. But... the stitching keeps coming away from the fabric. I am using muslin fabric. Any ideas please. thanks.
  • Anonymous Mar 24, 2014
    Iwant to know how to change feet fot a rolling stitch
    Master:
  • 539 Answers
  • 7 Answers
I've seen feet and plates for this machine on eBay. Just search for the model #.
Posted on Feb 28, 2012
I wondered if you'd gotten the parts. I have this machine and love it. According to my manual, you need the Rolled hemming stitch presser foot (part #X75592001) and the Rolled hemming stitch needle plate (part #X75873001). Good luck!
Posted on Jan 16, 2012
Where can i buy a new thread tree for my 1034d brother overlocker from betty c
Posted on Mar 23, 2009
Can I make rolled hem with a Juki MO 2366 N?
Most likely. Most overlockers can make a rolled hem. You will probably want to do a lot of practicing on scrap chiffon before trying it on the real thing. It involves using only one needle, both loopers, and making appropriate adjustments to the machine.
Serger 101 Threading the Juki MO 654de Machine for Roll Hemming by CKC...
How to Serge Rolled Hem
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Bernina has some very nice Serger Workbooks that could be helpful:
Bernina Mastery Workbooks
Nov 13, 2017 | Juki Sewing Machines
I the regular needle plate and presser foot
are you saying you need a presser foot and needle plate for a serger,, if that what you need, try these sites for the parts
sewvacdoctor.com
sewingpartsonline.com
Feb 18, 2016 | Sewing Machines
Serger is not stitching
... not quite sure what you mean by "not stitching", here are a few things to check. If the problem is more specific, please leave me a note with more details.
Let's start right from the beginning (for 4-thread overlock/serge):
1. According to the serger manual, ensure that the proper needles are being used. That they are inserted all the way up into their positions and that the flat side of the needle is facing away from you. The left needle will appear to be shorter that the right, that is OK, all is going perfectly.
2. Use four good quality spool of serger thread (good quality sewing thread is fine also) and place them on the spool or cone holders. There should be "little bucket looking things" that fit onto the cone pins to make the cones sit nice and straight, use them. Rattling thread will cause grief.
3. The first thread to be loaded onto the serger is the Upper Looper ...it is the big needle looking thing that swings left to right and back again above the sewing surface. Follow all the threading guided according to your manual, the threading guides are generally coded in a colour specific for this looper. Once the eye of the Upper Looper is threaded, place the thread under the presser foot and to the left. Presser foot down.
4. Next is the Lower Looper, the big needle looking thing that swings left to right and back again under the sewing surface. It can be a bit tricky in some sergers as the thread need to pass to the left and then back to the right under the sewing surface. Your manual should have a good diagram if you can not follow the threading guides on the serger itself. Again the threading guides are generally colour coded with a different colour but specific for the Lower Looper. Once the looper is threaded, it is important that the thread is placed directly OVER the Upper Looper as it comes out of the eye of the Lower Looper. Place the thread now under the presser foot and to the left. Presser foot down.
5. Thread the right needle front to back and place the thread under the presser foot and to the left. Presser foot down.
6 Thread the left needle front to back and place the thread under the presser foot and to the left. Presser foot down.
7. Hold the four thread ends firmly in the left hand and give each thread individually a good pull down over the serger and behind, this will ensure that the threads are all engaged in the tension dials.
8. Set the tensions to the middle number, although this may vary with the brand and model of your serger. If you have the manual check for the correct settings specific to your unit.
9. Set differential to 'normal', or '0' (if your unit has one)
10. Set stitch length to about 2 1/2 to 3.
11. Make sure that the blade is in cutting position. We can trouble shoot blade position later if needed.
12. Make sure that you have the overlocking plate installed ... not the rolled hem plate (if your serger has two plates). Some sergers use the same plate for both functions.
13. Using two layers of medium weight fabric do a test stitch, what is the result? Is a chain forming? Are there stitches on the fabric? Are they looking the way they should?
Hopefully this has helped you, please let me know.
Cheers.
Sep 01, 2014 | Sewing Machines
Tension to loose and missing stitches
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
use a scrap piece of fabric to sew on as you adjust the tension
when the tension is to loose adjust one number higher till stitch
looks good
here's 2 links for a manual one is a hardcopy & the other is a
pdf downloadable--one is a different price from the other
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d.aspx
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d-download.aspx
Sep 08, 2012 | Janome MyLock 634D Mechanical Sewing...
Can you do a coverstitch on the Brother 634D serger
I don't think so, the D in your model name would denote that it has Differential feeding but is probably a 3/4 Marrowing stitch only. So this means it would do 3 thread overlock, 4 thread overlock and you can probably set it up for rolled hemming too.
Coverstitch is fairly new to home sergers and is available on some machines along with the 3 and 4 thread stitches, but changing between the regular overlock and a coverstitch takes a few minutes. The model number will usually have a "C" in the name. Also, during coverstitch the blades are disenaged and don't trim your fabric so you still need often to go back with blunt scissors and trim the raw edge.
And sewing coverstitch can be finicky, with skipped stitches a problem. Use high quality thread and XL (extra long) or SUX (stretch extra long) needles to avoid this.
However some manufacturers are now making dedicated coverstitch machines; if you are assembling a garment with your regular serger, you can then just move over to the coverstitch machine to sew the hems and necklines and not spend 20 mins changing over your machine's functions. Much more productive.
You may wish to check out the Brother 2340CV, this is their dedicated domestic coverstitch machine. Link to product info is http://www.brother-usa.com/homesewing/ModelDetail.aspx?ProductID=2340CV
In the meantime, best solution is a twin needle to stitch the hem from the right side of the garment on your regular sewing machine, looks much the same, and you can get twin needles with a 4mm or 2.2 mm gap and in stretch and sharp tips for less than $10 each. Just iron up the hem about 1.5cm deep, and thread up your sewing machine with the twin needle and two spools of same colour on top (I just wind an extra bobbin and use this plus the original thread spool rather than buy two spools).
Just sew really slow as the twin needle builds up a lot of heat and will break if you push it along. I use this finish on all my knit garments and it works just fine. Sometimes I'll iron in a 2cm strip of fusible web inside the hem to give it some firmness in a neckline, then twin needle stitch at about 1.7 from the folded edge.
Hope this answers your question.
Oct 23, 2011 | Janome MyLock 634D Mechanical Sewing...
How do I set up my babylock serger for a rolled hem? What is the tension to be set at?
I don't know your babylock well, some of these have automatic tensions and electronic stitch selection. But a rolled hem is achieved on any overlocker in the following way; the actual dials and knobs might vary a bit.
Firstly there is a stitch finger that you need to change or retract so that the thread can roll the fabric rather than staying flat. For a normal seam this finger sticks out in the area where the loopers and needle form the stitch holding the cut edge flat until the seam is made over it. But for rolled hems you want to retract this finger so it does roll.
On the Bernettes this is a little lever in front of the stitching area that you pull back to retract the finger. Have a look around where the stitch forms and you should see the finger. Some machines, its a part you change on the needle plate with a screw driver, or just move a switch or lever.
You want the right hand needle in place, remove the left hand needle.
Thread upper looper with wooly overlock thread, this is a fluffy nylon that pulls flat under tension but relaxes and "fills" out once its stitched into place. Gives that lovely covered look you see on shop bought tablecloth edges. Your regular thread in needle and lower looper. Usually cutting blade to the right side as you want it to cut more fabric than in the seam so it rolls under. Now loosen off the tension on the top looper, (I use 2 on mine but this is something you need to finesse with each machine), and tighten up the tension on lower looper, (about 7). Leave needle tension alone.
Now test stitch on your fabric, and finess the upper and lower looper tensions until you get the lower looper thread almost not showing, it should be right up against the needle on the underside with the upper looper thread completely wrapping around top and bottom, pulling the fabric under.a seam like this.
Test stitch and adjust upper and lower looper until this is happening.
Now, turn stitch length down to close up the stitching, probably 1 or 0.8 if you want a real satin stitch look to the hem.
Because of the stitch density this uses thread so do the finessing first, then turn the length down.
That's it! Now right down the tension settings you used and keep handy for next time.
Sep 24, 2011 | Baby Lock Eclipse Serger
I need to switch to rolled hemming and can't find my manual
Is this on a serger?
Rolled hemming on a serger is usually achieved by doing the following: thread up for three thread overlock using right hand needle. Move blade to the right to trim fabric wider (so it rolls inside the seam). Put woolly overlock thread through top looper (this gives a smooth finish to the rolled hem). Loosen off top looper and tighten up bottom looper so the bottom looper is up tight against the needle thread on the underside. Test serge to get the stitch right, then turn the stitch length down to 0.5 to close it up tight (this uses loads of thread so I usually get everything else right first, then make this final adjustment). On my Bernette 334D tensions are R-Needle - 5, Top looper 7-8 and bottom looper is 3-4. Stitch length 0.5, differential zero.
And usually you flick a small lever or change a little finger on the foot or plate where the stitch forms, there is some variation here between models. Early Elna L4 and L5 locks you had a little finger you changed with a screwdriver on the pressure foot. Bernette has a little slide mechanicism near the blade that you flick forward to engage.
Hope this is of assistance to you - I went for a 2 hour lesson on my serger when I bought it and then came home and repeated all the techniques shown and then made notes and stapled all the stitch samples into a notebook so I could remember how I did it.
Also there are some great books on Serging, Nancy Zieman is one name that springs to mind. Or try You-Tube, she has some videos up there too showing different techniques.
Apr 27, 2011 | Janome Sewing Machines
Which needle do I take out to do a rolled needle
left one, rolled hem is usually a narrow seam so you remove the left needle, change the needle plate or flick a switch that changes the position of the thread finger under the foot and tighten up the looper tensions. You want the top looper thread to go around to underneath and the bottom looper thread to disappear against the needle stitching. You also need to close up the stitching density, by decreasing the stitch length.
Mar 02, 2011 | Baby Lock Eclipse Serger
I've just got janome 634d serger, how can i make the bottom of a T-shirt ? Thank you so much
If you want the bottom of the T to look like RTW with the double row of stitching, you cannot do this on a serger.
You can achieve the effect by using a twin needle, two spools of thread, bobbin and a straight stitch.
Make sure the double/twin needle will pass through the presser foot and opening in the needle plate below the presser foot.
Practice on a double layer of a scrap of the T shirt material as the tension may need to be slightly looser than the normal setting.
Apr 05, 2010 | Janome MyLock 634D Mechanical Sewing...
Coverstitching on White Speedylock serger
Your machine cannot do a cover stitch. Check the Brother website, they make a cover stitch only machine, it works much better than any of the serger/cover stitch combination machines, and it is a lot less money.
Nov 19, 2007 | White Sewing Speedylock 1600 Mechanical...
Brother Lay-In Thread Serger Mechanical Sewing Machine Logo
649 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
