Question about GE Monogram ZV1050SFSS 42" Island Chimney Hood
The fan is working but slower than normal
The fan works but much slower than normal, per user manual cleaned filters re-install, still the same. It happen while the fan was working on high, it suddenly slowed down! the are to funs, both works but on slow speed. Any suggestion?
Marc
  • 3 more comments
  • mbeg49 Nov 09, 2008
    No brainer advice, I was expecting advice from some one who has at least a tiny knowledge of the product. from the response it is obvious he/she is very ignorant about the product. This product has two motors, they are working fine, except at the 40% of normall speed, no noise. Even at lower speed it shut itself off about 5 minutes. it seems like something is getting hot and cutting of the power. Please if you are not sure what the issue is do not replay with supid answer. Thanks
    The fan only works at less than 40% of capacity and shut itself off after 5 minutes or less, new filter installed, both fan motors operating, all buttons of the electronic boared functioning. Is there any relay or fuses that causing mulfunction, or low voltage? The unit is about 4 years old, but seldom used and was working fine just two weeks ago.
    Mohammad what do you mean by "check he contencer replace the moter" Could you type in English please.
    Ginko, there are two fan motors, and both works at the lower speed just fine without any noise or hum or getting hot, the blades are very clean, since the hood was hardly used, but shut itself off in about 5 minutes, is there anything that causes lower voltage? Like relay or fuses.
    voodoomox, the hood has two motors and are very clean, both work at the lower speed just fine for about 5 minutes before shutting themself off, I touch the motors while running, neither gets hot or make funny noise as sick motors usually do, and further the possibility of both motors go bad at the same time is slim.
  • 728 Answers
You might have a small short that causes the fan to go at a slow speed and to cut off after five minutes so that it will not catch on fire. You may need a new motor, but get it checked by a professional to see why both fans are acting the same way.
Posted on Nov 09, 2008
  • Jazz Boyce
    Jazz Boyce Nov 09, 2008
    It also might be the circuit board running the fans that could also be faulty.
  • 899 Answers
If just one of the motors is causing a strain the circuit will protect , the motor doesn't have to get hot or make noises to cause the protect circuit to engage and shut down
the only way we can find out whats going on is to do some tests , can you do some meter testing?
    Scholar:
  • 53 Answers
I assume that you have the complete manual, if not you can find it here;
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=ZV1050SFSS&SITEID=MON2&TABID=4
I find it a little odd that on page 8 of the manual it states your exact problem, almost like they know it's a problem area. Still
if you are able to take the unit apart and get to the control buttons are you able to check and see that they are not jammed up? from left to right button 5 is used to control the delayed timer function. I would look at this one first check that it is not constantly being pressed in or gummed up causing the unit to think that you are depressing the button constantly.
I mention button 5 as the first delay time is 5 minutes you say that after 5 minutes the unit turns off.
Hope this was helpful, even if its just giving you another idea.
    Sergeant:
  • 207 Answers
Seeing as there are 2 fans and BOTH are working at diminished speeds, it is likely to be a problem somewhere along the speed controller circuit.
First I would check the terminals on the controller switch.
Look for any corossion or visible scorch marks.
Also check the wires leading from the control circuit to the motors for melted wiring or burn marks.
Any Damage discovered should be repaired by an authorized repair tech or someone skilled will electrical repair.
If you do not find any obvious damage, the next step depends on how comfortable you are working with electrical/electronic testing. Using a Volt Ohm Meter (VOM / Multimeter) and or continuity tester, you or a service tech should check each of the 4 speed control circuits leading to the motor(s). Any circuit found to have an open or short circuit should be repaired/ replaced.
Hopefully this helps you out,
and thank you for choosing FixYa
Dave
    Genius:
  • 1,689 Answers
If you can remove the fan itself from the mount, do so and clean the properller, the motor and the case if it is possible. dirt build up may cause the fan to have less power. you may clean the motor part then put some light axle grease on it or a contact cleaner. if the issue persists replace the motor.
  • marlon john madrid
    marlon john madrid Nov 09, 2008
    possibly, when you cleaned the motors, did you check if they have scratches, a contact point between the coils and the magnet?
    President:
  • 1,952 Answers
Check he contencer replace the moter
  • mohammed marika thambi
    mohammed marika thambi Nov 11, 2008
    change the best moter and compresser
    mohammed marika thambi Nov 17, 2008
    replace the capacitor with high micro farad
    President:
  • 624 Answers
You can try spraying some electronic contact cleaner on the fan motor windings and see if it helps. Once you spray it you can turn the fan by hand to work it in. If that does not help, you either have too low of voltage driving the fan, or the fan must be replaced.
  • GE Master
  • 19,396 Answers
The fan should have a clutch that regulates the speed , when this is defective, it may run slower than normal.
  • Ginko
    Ginko Nov 09, 2008
    Check also this website:
    Tips on how to repair your kitchen hood
    I think they are right , it is a faulty motor.
    I quote:
    1. If the fan instead of turning hums, or moves very slow, or becomes very hot then you might need to replace the fan motor.
    2. Remove the motor and replace but before doing so make sure that you have properly disconnected the power supply.
    Genius:
  • 1,550 Answers
Motor is in bad condition .
Fan is not working but makes a humming noise at lower speeds and clanking noise at highest speed. When last working there was the clanking noise when I turned off the fan. Please help.
Then turn it off immediately just to be safe that nothing will be broken, can you see the interior? Is there anything broken or loose that might cause the noize? If yes remove.
If not try to clean it with a little cloth or anything, maybe it is too dusty.
Mar 10, 2016 | Electrolux RH36WC60GS Designer Glass...
I have a Mieli DA2210 rangehood, just out of warranty. Fan is working as normal but the lights will not switch off.
take the light switch out and clean it with CRC electric parts cleaner. Reinstall and hope for the best.
Feb 28, 2015 | Miele DA2210 Cooker Hood 8268473 Fan...
My downdraft vent no longer removes cooking fumes and smells for days after cooking. We have changed the screens, but still have residue coming from the vent inside the cabinet. Does this vent need to
Remove the motor together with the blower wheel, go to the local self service car-wash and use the engine de-greaser cycle (if not available, buy a can at the auto supply, spray the fan blade and let sit for a while) and get all the grease of the fan blades. make sure the fan blades are cleaned thoroughly. the fan will now ran quietly and will remove all the grease away. in the future, clean the filters often.
Jan 06, 2014 | Kitchen Ranges
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
Took filter out to clean and now have a humming sound when the hood is turned on but the motor is not working.
When you took the filter out to clean it you got something against the fan blade....probably when you reinstalled the filter,,,pull it back out and try the fan... if it works then you know the filter is installated wrong...
heatman101
Mar 14, 2011 | Baumatic Kitchen Ranges
We would like to replace or clean the fan filter
This is a charcoal filter and cannot be cleaned out. If your extractor is no longer working efficiently then you should replace the charcoal filter/s.
Nov 21, 2009 | Vulcan 36" WIDE ELECTRIC(Click Here): WALL...
Fan has a humming noise and locking up
a.if there were a dead bird inside, you'd know it from the smell! if the outside vent has the proper hood on it, it's doubtful a bird could get into it. possibly a roof-rat, but still- the smell!
b. have you 'de-greased' the filter lately? clogged filter can cause airflow problems, as well as allowing fan blades to become greased up and unbalanced, which could cause a noisy condition. if you can- remove the filter unit and check the fan blades for crud. use a gentle application of windex, rubbing alcohol, or some other gentle solvent to clean the blades. the leading edges usually pick up the most crud. you should be able to see this! carefully, using q-tips, or a small brush, clean off the crud! the fan's probably out of balance. WD40 works pretty well, too. also lubricates the shaft bushing that the blades are attached to. make sure the fan is turned off! duh!! good luck! also- soak the filter in hot water and a good de-greaser for a while, 'til you can see light through it. it's probably aluminum mesh- so use very hot water and a goodly amount of 'grease cutting' dish detergent. rinse well.
once again- good luck! the filter is probably held in place by clips. once removed, you will probably need a flashlight to work on the fan blades. put paper towels, or newspaper down to catch drips!
Sep 29, 2009 | GE ZV750SY Kitchen Hood
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
Hood fan works but displays the letter "C" ?
wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
Feb 22, 2009 | KitchenAid KWCU205HSS Kitchen Hood
Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Dec 20, 2008 | Imperial C2036PS1-TW Kitchen Hood
GE Monogram ZV1050SFSS 42" Island Chimney Hood Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
