Question about Olympus FE-115 Digital Camera
Olympus FE-115 : wont turn on..turns iself off!!!
I just purchased this camera not too long ago and it worked perfectly fine. However, 2 or 3 days ago it stopped working and it wont turn on. It automatically turns itself off even though it has new charged batteries!And a red and green light begin to flash! what is the problem!!?? im not a electronic expert so PLEASE help!!
  • Anonymous Nov 08, 2007
    I've had the same problem and have put three different sets of batteries in to ensure it wasn't the problem. It still will either not turn on or only takes about 2 photos then turns itself off.
  • SoonerDee Nov 12, 2008
    I have a similar problem. I thought if I downloaded all my photos off the memory card that would solve the problem. It didn't. I have new 2450mAh rechargeable batteries. The orange and green light blinks, the lens will go out sometimes but after just a second it retreats. I have no clue.
I've experienced a very similar problem. I took our camera to a Bridal shower with 2 sets of freshly charged (I validated the charge) NIMH rechargeables plus a set of new alkalines. Regardless of which batteries I used, the camera indicated low battery after one or two pictures were taken, if it would take one at all. Its NOT a battery problem in my case.
Posted on Jun 14, 2007
I had the same problem and i called up cutomer support on 1300 659 678 (Australia) and they said that the problem may lie in your batteries. It was advised that you use Lithium batteries, and to avoid use of Alkaline, since they dont have the required power to operate the camera which is why it turns off right away. As to what type of rechageable batterires to use i am not sure, i think it was Nickel-metal-hydride (NiMH) batteries. Hope this solves your problem.
Posted on Sep 26, 2006
SOURCE:
Problem with the Olympus FE-115 Digital Camera my
Unfortunately, the picture error message means that the image been modified such that the camera can't read it. It is possible that the camera thinks the picture was taken by another camera. Since the picture is still good when you check it with the computer, it hasn't been damaged. Archive the picture and make sure to back it up after it goes on the computer. (If the computer couldn't view it, then you'd need some sort of file recovery software and might not get the entire image back.)
Manuals for the FE-115 are available from the Olympus site: http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?id=1227&fl=8 .
I hope this helps.
Mar 10, 2011 | Olympus FE-115 Digital Camera
MY OLYMPUS FE-115- THE FLASH DOESN'T GO OFF
You can try to reset the camera back to factory settings to see if the flash will start working again. To reset: Have the camera in shooting mode - press the down arrow - camera will indicate reset or cancel - highlight reset and press ok - the camera will be back in factory settings - see if flash fires - if it does then fine - if you see a red flash charging icon blinking on the screen this is a repair issue and the camera needs to be sent to Olympus for service.
Apr 12, 2009 | Olympus FE-115 Digital Camera
Need olympus master for FE-115
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
(http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version).
That sounds as if it may be a repair issue with the chip inside the camera that controls image processing. You may want to call Olympus Customer Service to discuss repair policy. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 11, 2009 | Olympus FE-115 Digital Camera
Repairs
i have a olympus FE 210 i had this less than a year ago when my memory card is in the camera the camera does not turn on but when i remove the memory card the cam works fine. please Help
Jul 24, 2008 | Olympus FE-210 Digital Camera
I purchased an olympus fe-330 8.0 megapixel camera about a month ago and worked ok until about a week ago when it just wont turn on. i have tried to charge the battery but the red light only comes on for...
when the red light is off, it means it is fully charged.
May be you are puting it wrong side in the camera. check the arrow to put in the camera
check with the service centre.
Jul 10, 2008 | Olympus Cameras
Why my camera wont turn on?
Hello.
When the two led's blink, that is telling you that the batteries are dead. Try replacing the batteries with FRESH ones and that should help.
NJ
Nov 24, 2007 | Olympus FE-115 Digital Camera
Olympus fe-100
Well try the Olympus tech support site they may have a solution for you- this is a malfunction that could have a simple remedy
May 26, 2007 | Olympus FE-115 Digital Camera
Screen is blank
You tell me that you tried new batteries. Have you tried a set of NiMH batteries? They are the best for digital cameras. Please try a set, preferably ones rated 2200 or higher. If this doesn't help, the lens could be jammed. Hang onto the batteries though, because they are rechargeable and can be used in anything that takes AA batteries.
Apr 14, 2007 | Olympus FE-115 Digital Camera
Olympus FE-115 Digital Camera Logo
497 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
