Question about HP Pavilion dv6000z Notebook
Yahoo Messanger Install Problem
I downloaded Yahoo messenger version 9.0, it kept messing up and it took ages to load. Tried to go back to version 8, but kept getting "Co Create Instance for the My Yahoo DLL failed."
What can I do to fix this messenger problem? I cant install yahoo messenger
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to re-installed yahoo messenger!!
or
may there's a bug in your os
try refomat it!!
Posted on Oct 30, 2008
Everytime i try to send a file via yahoo instant mess. i get an error and then it stops sending it
Check your messenger client is up to date... Try to use messenger version 8 or 9 ... bugs are fully fixed for 8.I think if you try using 8 version it will help.
Thanks
Dec 07, 2009 | Yahoo Messenger
I downloaded Yahoo messenger version 9.0, it kept messing up and it took ages to I downloaded Yahoo messenger version 9.0, it kept messing up and it took ages to load. It comes to 99% and then says not...
Hi no problem..u r trying to install online setup.so u got that problem..
u can download full offline installer from here..
http://download.yimg.com/ycs/msg/dl/msgr9/us/ymsgr900_1912_us.exe
download it..and install works 100% sure.
rate me if u satisfied by my solution
DOWNLOAD a patch for removing ads from yahoo messenger 9 final
http://download.softpedia.ro/dl/6970db9cae4ff094fd0c7c83bb1d4ddb/48e20ac5/100018884/software/INTERNET/IM/y.addsremover.zip
Dec 19, 2008 | Yahoo Messenger
My yahoo Im stops working
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Here is the best help/fix it sites I have found so far for Messenger,chat,and Yahoo in general. http://www.helpbytes.co.uk/ This one for Vista http://www.vista4beginners.com/tips-and-tricks
many problems solved using this link http://www.freecreed.com/
Dec 11, 2008 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
Dec 09, 2008 | Yahoo Messenger
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Step 1: Uninstall the Yahoo Messenger
Step 2: Go to Run
Step 3: Type REGEDIT
Step 4: Delete the Yahoo Messenger and try re-installing it again.
Regards
Nov 27, 2008 | Yahoo Messenger
Try uninstalling Yahoo Messenger and then reinstall it. If that does not work it will have to be removed from the Registry. It may have a bad driver in the registry. If you are not familiar with or experienced with the registry I would not venture into it.
Hope this is of some help. Bud
Oct 19, 2008 | Sakar Yahoo 4D Internet Soft Scroll Mouse
Yahoo Messenger 9
yahoo messenger 9.0 was not loading for me....so i tried to re-install it..tht ddnt work...thn i deleted all the files manually and removed the program... but now wen i install it it stops at 99%..i saw somewhr a suggestion...it helps to reach 100%but again the loading prob.. so in short nothing worked out.. i tried several times to install... it stops at 99%.... YAHOOOOOOOOO plzzz help. i use windows XP.
Oct 05, 2008 | Yahoo Messenger
I'VE GOT IT!
Whether you are using XP or Vista, go to System Restore, follow the instructions and you will be taken to a point in the past that you either a) didn't have a Messenger hang or b) before installed Messenger and then you can do it again.
It doesn't affect any documents.
I should have remembered this myself but one of the guys on a forum that I am a member of reminded me of this solution.
Go to it...it's cake.
Sep 15, 2008 | Yahoo Messenger
HP Pavilion dv6000z Notebook Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
