Question about Panasonic PT-53WX52 53" Rear Projection Television
I'm having a problem with my Panasonic PT-53wx52
My tv has worked all day. For some reason or another, at 8pm my boyfriend went to turn the tv on and nothing happened. Its red blinked three blinked three times and then several times after that. We unplugged it and the tv came on for about two seconds and then turned off again. And again its red light blinked three times and several times after that. An ideas?
  • Panasonic Master
  • 3,459 Answers
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Posted on Apr 18, 2010
First and foremost, DVD's still play perfectly and the colors are beautiful, perfect and alligned on my PT53WX52. However, on Regular TV-(Cox Cable) every human being appears to be the color similar to...
Replace the cable from your cable box to television. Try one from one of your other cable boxes before buying one, but I highly suspect the actual cable from box to TV is bad
Feb 24, 2011 | Panasonic PT-53WX52 53" Rear Projection...
The colors on my tv doesn't line up right. It has a 3D look and i tried to converge it. It will not let me do it. Its a panasonic HDTV PT-47WX42, PT-47WX52, PT-53WX42, PT-53WX52, PT-56WX42, PT-56WX52
set uses two of the STK-392-110 chips for convergence.
Both will have to be replaced.
I have start to finish step by step instructions for this repair based on me doing it in hundreds of these sets.
If you want the instructions, do you have a email?
SD TECH
Jan 15, 2011 | Panasonic PT-47WX42 47" Rear Projection...
Hello need help on tv set
SHORT is on the 140 volt line--usually the horizontal output transistor is shorted, and there may be a simple reason for this.
Let me know if you are able with help to test the part indicated. I know the best way to work on this set safely and quickly.
I am in San Diego, and my name is Steve.
SD TECH
Jun 04, 2010 | Panasonic PT-53WX52 53" Rear Projection...
Cracked bulb or lamp?
There are bad solder connections on the Convergence Amp IC's. When you moved it , the connections that were loose are now disconnected. Resolder the pins on these IC's and you should be ready to watch TV again.
Aug 09, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Projection HDTV won't power up, red LED flashes in front
i am having same problem. 3 flashes indicate convergence problem according to auto diagnostics that you are seeing(info from service manual).
i am starting by replacing stk392-110 convergence amp ic($6 at electronic.com). just ordered them, will let you know how it goes. please check this site-- http://biobug.org/ht/panasonic/ -- very good step-by-step on procedure.
will need service manual afterward. email me if you want copy.
good luck and godspeed,
bridgeman001
Apr 17, 2009 | Panasonic PT-53WX52 53" Rear Projection...
My Panasonic PT-53WX52 rear proj. TV won't turn on?????????
from what I have found out their is a problem with the power unit inside the television. Could be a convergence chip that shorted out
Nov 20, 2008 | Panasonic PT-53WX52 53" Rear Projection...
The PT-53WX52
This looks like a problemcausing the shutdown circuit to trigger. The shutdown circuit prevents the TV from being further damaged by an overcurrent or overvoltage event. The overcurent event is caused by a component being over driven and thus it decreases in resistive value causing an increase in current, The over voltage event is caused by a component increasing in its resistive value either due to an open circuit or decrease in the component's conductive area. In any event the shutdown circuits senses these eventes and shuts the TV down to prevent futher damage.
I would suggest taking the set to your local TV repair shop.
I hope this helps,
Shuttle83
Nov 16, 2007 | Panasonic PT-53WX52 53" Rear Projection...
PT-53WX52 53 in. Rear Projection
You have defective convergence amps. At least one. I would also look for any burnt or open resistors.
Dec 18, 2006 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-53WX52 53" Rear Projection Television Logo
503 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
