Question about Berkel 827E Gravity Feed Deli Meat Slicer
Globe Meat Slicer Model # 500 motor runs blade not turning
  • Anonymous Mar 13, 2014
    Slicer hard to push
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Posted on Dec 24, 2008
Bearing is froze up, use 1&18th thin walled socket to remove nut to free assembley after removing blade. lift out and inspect fiber gear, if good than unit probally needs replced as repair can be a hassle. whole unit can be purchased at for 199.95 then just drop it in and tighten up the lower shaft holding nut& replace the blade assembley .....JB
Posted on Feb 12, 2010
  • Godzilla Oct 02, 2013
    I have a Globe 500 Slicer. I am trying to rebuild the Knife Plate hub assembly because the bearings are frozen. Also I was able to get the end off with the lock washer and slide the washers and bearing out but the other bearings are not coming out. Do I have to remove the Bronze gear to get the others out or do they come out towards the knife plate coupling?
2 Suggested Answers
  • 112 Answers
SOURCE: Globe commercial Meat slicer
I'm not familiar enough with globe slicers to be an accurate source of info. Sorry.
Posted on Oct 29, 2008
Bolt and washer for rival meat slicer mod 1101e/3
Meat Slicer Parts ' eBay
  1. Cached
  2. Similar
Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage ... Rival Food Slicer Meat Motor Holder SCREW 1101E-5 Accessory Spare Part.
Rival Meat Slicer ' eBay
  1. Cached
  2. Similar
Vintage Rival Electr-O-Matic Deli Meat Food Slicer 1101E-2. $45.00; Buy .... Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage. $7.99.
Food Prep & Choppers - Rival Products
  1. Cached
  2. Similar
HM-743 - Rival® Hand Mixer Instruction Manual · 1042-WN - Rival® Folding Food Slicer Manual · CN-742 - Rival® Electric Can Opener Instruction Manual ... rival meat slicer mod 1101e 3 Google Search
Dec 23, 2016 | Rival Food Processors
Where can I get gears for Gourmet Living Shopko meat slicer?
Unfortunately meat slicers in this price range are throw away items if they break. Neither Gourmet Living or Shopko actually make this slicer so it is nearly impossible to find parts for. It is probably made in China.
I would suggest you spend a little more money (90.00) and get something like Nesco FS-140r. It has a one year warranty and you can buy parts for it thru Nesco.
Mar 26, 2014 | GOURMET LIVING Shopko Meat Slicer NO...
How to remove berkel slicer blade
my berkel slicer model 818 the motor runs and the automatic table will slid but the blade does not torn
Jun 01, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
I need motor parts or a replcement motor for my globe gravity feed slicer
I would get it rebuilt, most or all electric motor places will do it
Aug 20, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
Model 1101E Rival Food Slicer - grinds to a holt.
Im looking for the nut or bolt that holds the blade
Feb 01, 2009 | Food Processors
Hi, I have working on meat slicer my whole life and can help you.
What normally happens is this. The bearings in the knife hub (this is the unit that the knife attaches to and spins) is starting to fail.
The gear on the knife hub is made out of a fiberous material and the worm gear on the motor is made out of metal, so when the bearings start to fail and cause resitance in the hub, the metal motor gear starts to eat the fiber gear on the hub and eventually wears a big chuck out of it. Then the motor spins free and doesn't make contact with the hub gear.
How you can check if this is the problem is this. You need to keep the power switch on machine in the off position and turn the blade a 1/4 of a revolution. Then turn the machine on, what should happen is that the blade will spin some and stop again.
The proper fix for the machine would be to rebuilt the knife bearing unit and replace the hub gear, motor gear and hardware.
In regards to the Chefmate. This is a design flaw of Globe and I told them about this when the machine first came out! The know is on a steel shaft that goes thru the aluminum body. The steel shaft starts to corode and also rust, then it freeze in the frame. What has to be done is this. This assembly needs to taken about sanded, lubed and put back together. The best way to permently fix this is have a machine shop machine the frame out and install a Oilite Bushing, these are impregnated with oil and it will never lock up again.
Where are you located? Let me know if I can answer any other questions for you.
If you have any other questions, you can call me on my cell 201-274-6274 or e-mail me at Thank you
Best regards,
Oct 26, 2008 | Kitchen Appliances - Others
Berkel 827E Gravity Feed Deli Meat Slicer Logo
2,164 people viewed this question
Top Berkel Kitchen Appliances - Others Experts
john raffaele
Level 1 Expert
Tom Chichester
Lawrence Oravetz
Are you a Berkel Kitchen Appliances - Other Expert? Answer questions, earn points and help others
