Question about HP Officejet 4315 All-in-One Printer
Printer just will not print
It will turn on but is in fax mode i can't get it to go to print mode and if i shut if off when i turn it back on after a while it will print
  • need8break1 Nov 15, 2008
    This is second printer same problem-sucks
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to re-installed the driver of your printer!!!
Posted on Oct 30, 2008
5 Suggested Answers
  • 526 Answers
SOURCE: PRINTER STAYS IN FAX MODE WHEN I WANT TO PRINT
if you push the copy button you will be in copy mode.
are you saying you want your default to be in copy?
Posted on Apr 19, 2009
Mix-it-up
  • 832 Answers
SOURCE: "Receiving Sleep" on Brother Fax 4100
you might have to change the settings for the switching time into stand-by. plz have a look into the manual which describes these settings (zero seconds are possible)
Posted on Jan 10, 2008
  • 144 Answers
SOURCE: HP Officejet 4500 keeps defaulting to fax mode
check the setting like menu look in there somewhere
Posted on Jun 05, 2009
  • 14 Answers
SOURCE: how do i change from fax back to printer?
Find The Fax button and click it
then its normal :)
-JON AKA MAYOROFSWORD/SPRAYERZ.
Posted on Aug 11, 2009
I change the cartridge but it stills display put in cartridge
Hold down the power button. Let the printer shut off. Turn it back on. From Windows Start button, go to Control Panel - Printers & Faxes; right-click on Canon MP390, click on Printing Preferences, open the tab for Maintenance, click Quiet Mode and choose Always Use Quiet Mode. When the error recurs, cancel all pending print jobs: double-click on the printer icon in the tool bar (bottom right corner of monitor) to open the Print Queue, click on the jobs, then press the Delete button on the keypad. After all pending jobs are deleted, power down the printer by holding down its On/Off button. After 2+ minutes, turn it back on & try again. Depending on how frequently you use the printer, you may find it's time for a replacement.
Dec 05, 2012 | Canon MultiPASS MP390 All-In-One InkJet...
I own officejet 4215v it is stuck in the fax mode and I can't get it to go to print.
Hello and Welcome to FixYa!
Sir this problem is due when by chance the Fax Mode is selected as default. To get to the print mode you need to change the mode to print. Try the following:
Click Start >> Print and Faxes (if you are using Win Xp) or Devices and Printers (if you are using Win 7) >> There will be the list of HP Office jet 4215 Fax and HP Office jet 4215 Printer. >> Right click on HP Office jet 4215 Printer ans Select as "Set as Default"
Now try to print again. If printer is still struck on the Fax Mode then possibility is that your printer is locked, In this case you need to Reset the printer: Follow the given steps to do this:-
  • Unplug the power supply from the rear of the product.
  • Unplug the power cord from the electrical outlet, power strip, or surge protector.
  • If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  • Wait 15 seconds.
  • Reconnect the power cord to the power module.
  • Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
Now turn the printer On and now try to print again. I hope if first solution do not work then this will solve the problem. But if still it struck to Fax Mode then its may be a technical or hardware issue, You need to contact HP Support Center to solve your problem.
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 11, 2011 | HP Officejet 4215v All-in-One Printer
Cannot get printer to print it is in fax mode
May be the default printer icon in printer and faxes (if the OS is XP) is the fax and not the printer...
Jan 23, 2010 | HP PSC 2410 All-In-One InkJet Printer
Incoming faxes do not print, fax report reads 'power fail' and diplay reads 'low memory' - Can you help?
First, does the machine print normally from a computer or when making copies?
If so, then most probably you have enabled a private receive fax mode. In this mode, faxes are not printed immediately upon receipt (to prevent unauthorized people to read them), but are stored in memory, waiting for an authorized person to come and print them, providing a PIN (password).
To print the faxes stored in memory, do the following:
- press FaxMenu
- using arrow buttons select "receive"
- press OK
- using arrow buttons select "print faxes"
- press OK
- using the alphanumeric keypad enter the PIN/password and press OK
THe previously received faxes should print..
SOmeone must have turned this option on, so ask that person what he/she entered as the PIN.
Dec 04, 2009 | HP Laserjet CM 1312NFI Color Printer
Jun 05, 2009 | Office Equipment & Supplies
Printing fax
take the paper tray out and shut the machine down also cancel out any printing in the cpu then reboot the printer good luck
Jan 01, 2009 | Brother MFC-5840CN All-In-One InkJet...
Receiving faxed
when the machine goes into energy save mode it will still receive faxes. (energy save is a low power mode the copier is still on and can accept faxes, print jobs and copy jobs)
however if the machine goes to auto shut off it will not.
(auto shut off will after a set amount of time turn the power switch on the copier to the off position and the copier can not be used until it is turned back on.)
you need to turn the copier off, hold down 0 & 8 and turn on then type in 206 press start, key in 20 press set then turn the copier off and back on. this will make sure that auto power off is not enabled.
i hope this helps you.
Jun 01, 2008 | Toshiba e-Studio 350 Copier
Printer won't print
i would gather that you need to get back in to menuy and got to fax mode , but make it state auto fax mode
so that when faxing is complete it will auto go back to printer status
we get the same thing here at my work but me making the menu go into auto fax mode seems to handle the trick
i hope tihis is helpfull and if not let me know cause thats all we use here at work is hp all in one printers i will check for you and just give me model number ok
richard from chicago
Apr 07, 2008 | HP Officejet 5510 All-In-One Thermal...
Lexmark x6170 random shut off while printing
I think the power saving mode is on your printer ?try setting to off mode or 2 hrs mode...
Mar 13, 2008 | Lexmark X6170 All-In-One InkJet Printer
Jan 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
157 people viewed this question
Seeker5211
Seeker5211
