Question about Kenwood KDC-128 CD Player
Nothing working i had the kenwood kdc-128 cd player in my car and one day i took the cords out the back of it and i hooked this alpine cd player up to it (because i was going to replace the kenwood one).i hooked it up with the same cords from the back of the kenwood cd player and the alpine cd player wouldnt work so i then hooked the kenwood cd player back up and it wouldnt work. it wont come on or anything. i checked all the fuses on the car and the cd player and i still cant figure out what happened.
  • Anonymous Nov 29, 2007
    i unhooked my battery cable and hooked it back up and now my cd player want come on
  • Anonymous Mar 15, 2008
    when i turn the kenwood cd player on in my car it say enter code...? an i need ah code so it can work...?
5 Suggested Answers
SOURCE:
MrLard
  • 94 Answers
SOURCE: KDC 128 CD Player
It could be that the player is going into protect mode. This is normally due to a short in a speaker cable, or one or more of your speakers is blown. Try disconnecting all of your speaker cables at the speaker end and make sure the connectors don't touch. Power it up again and see if it stays on. Bear in mind you won't hear anything. If it powers up. Carefully plug each speaker back in. It will power off if you plug in the dud! If it still doesn't power up. disconnect all of your speaker cables at the player end. If it powers up this time one of your cables is shorted. Same as the speakers, plug one pair of wires in at a time to find the dud. If it's still switching off. It could be a blown circuit on the output stage of the amp. Here's a silly question. Does the player get hot? All this assumes that you have had this player working with these cables and speakers before. If not check that the speakers are the correct rating (Resistance in Ohms) for the player. And lastly here's where you can get a manual http://www.kenwoodusa.com/Support/Car_Files/#_
Posted on Sep 10, 2007
SOURCE: i hooked up my kenwood kdc 128 cd player and nothing works
i had the same problem as you, i own a 98 ford escort, and i couldnt find a wiring diagram that matched the ones in my car . i managed to connect the constant (red) and switched (yellow) to the wires in the car but i had made a mistake with the ground (black) . so i re connected it to where its suppose to go so now the head unit actually lights up and turns on.
now i have another problem because my head unit doesnt stay on for any longer than 1 mintute
Posted on Aug 27, 2009
  • 70 Answers
SOURCE: can get kenwood kcd 128 to turn on
ok black is ground, red is remote, yellow is battery, orange is illumination, make sure the antenna wire is in and you hold down the SRC button for about 3 to 5 seconds. please vote.
Posted on Jul 29, 2010
kenw392
  • 2226 Answers
SOURCE: i have a kenwood kdc 128 and when i hook it up the
did you try pressing the source (src) button?
Posted on Sep 23, 2011
How do i install my alpine cd changer to a kenwood mp528 unit
It is unclear which Alpine CD changer you have and what output connections are available from it.
However your Kenwood unit has Aux input terminals at the back. With appropriate cable connectors you should be able to hook the two up. In the Kenwood you will have to select AUX in menu when playing CD changer. Download user manual for Kenwood from this site.
http://www.kenwoodusa.com/Support/Car_Entertainment/
Search using full model number KDC-MP528
Sep 04, 2014 | Kenwood Car Audio & Video
:I shorted out my kdc 128 head unit and i switched all the fuses but it still wont turn on. any ideas?
Firstly, the main wires from the KDC-128 you need to check are:
RED - this should be connected to the vehicle's +12v IGNITION wire.
YELLOW - this should be connected to the vehicle's =12v BATTERY wire.
EARTH - i) some tuners will only earth when the tuner itself, is screwed into the vehicle's chassis (i.e. a metal mounting bracket); ii) some tuners require the BLACK wire to be attached to the vehicle's chassis (i.e. a metal mounting bracket).
Secondly, if the above wires are connected correctly, then you should suspect the fuse on rear of the tuner has blown (even if it LOOKS ok). Replace and see what happens.
Thirdly, if all above are ok, then you have a short somewhere on the vehicle.
Jan 12, 2013 | Kenwood KDC-128 CD Player
Can get kenwood kcd 128 to turn on
Jul 29, 2010 | Kenwood KDC-128 CD Player
Ineed a manual user guide Kenwood kdc 128 cr
You can get your manual here:
http://audio.manualsonline.com/manuals/mfg/kenwood/kdc-128.html
Nov 23, 2009 | Kenwood KDC-128 CD Player
I hooked up my kenwood kdc 128 cd player and nothing works
Mar 05, 2009 | Kenwood KDC-128 CD Player
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back...
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Jan 02, 2009 | Kenwood KDC-128 CD Player
Kenwood kdc-128
The remote lead on the back of the radio should be a blue wire with a white stripe. If this wire is not present, then you can use an accessory lead in the car or the accessory lead (red) at the radio harness. Hope this is helpful.
Sep 14, 2008 | Kenwood KDC-128 CD Player
Im loose my wires
Here you go:
This is the wiring diagram for most all the kenwood radios for the last few years. Yours included.
If you need more help just ask.
A good rating would be appreciated.
Jun 21, 2008 | Kenwood KDC-128 CD Player
Dead Kenwood KDC-128 CD Player Is there a "reset"
KENWOOD MADE TWO DIFFERENT EDITION FOR THIS AND SOME OTHER MODELS. YOUR WILL NEED TO CHECK THE SERIAL NUMBER AND YOU CAN CHECK WITH PACPARTS AT pacparts.com THEY WILL GET THE RIGHT ONE FOR YOU
Dec 13, 2006 | Kenwood KDC-128 CD Player
Kenwood KDC-128 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
