Question about Maytag 24 in. MDB7650AWS Built-in Dishwasher
My Maytag dishwasher does not drain water after the wash cycle is over
I have Maytag Jetclean Dishwasher-quiet Plus.
Model # MDB6650AWW
Serial # 27690773ZQ
Motor 5,5 A 120V 60 HZ
Heather 6.0 A
Best regards.
  • 2 more comments
  • olabrk Nov 11, 2008
    Thank you very much! You are the BEST!
    Ola
  • terrytlw Mar 06, 2009
    I have a Maytag Quiet Series 300 (Model#: MDBH970AWQ). After the wash & dry cycle has completed, there is still water at the bottom of the dishwasher.
  • Anonymous Mar 31, 2009
    MINE WONT DRAIN EITHER AND IM THINKING BY THE LOOKS OF THE HOUSING THE MOTOR MAY REVERSE OPERATION TO DRAIN. OTHER TYPES THAT IVE SEEN HAVE A TYPE OF FLAP THAT DIRECTS THIS WATER FLOW EITHER TO WASH OR DRAIN. SO HERE I AM ATTEMPTING TO FIGURE OUT IF I HAVE A BAD WINDING OR IF ITS ANOTHER ISSUE. DOES ANYONE KNOW WHAT THE OHMS SHOULD READ FOR GOOD WINDINGS ON ONE OF THESE MOTORS? THANKS.
  • Anonymous Mar 17, 2014
    how long should the light wash cycle run?
  • 172 Answers
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
Maytag jetclean quiet plus fills but wont wash or drain.
The mother board is going out, or the drain pump is failing. Try un plugging it...... by which i mean turning the power off to the unit and doing a soft reset. See if it recycles into the normal mode and works.
Mar 06, 2015 | Maytag Dishwashers
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Water will not drain out of dishwasher
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag JetII dishwasher
try removing the wash arms( should be a center mounter ***** that releases the wash arm. possible that hte holes in arm have become clogged w/debris. although oyu cant seperate the arm try getting the debris out from the large center hole.
Mar 11, 2008 | Maytag 24 in. MDB8750A Jetclean II...
Maytag dishwasher
Many dishwashers now have seperate drain and wash pumps. Often the wash motor stops because something is caoght in impeller. You need to remove lower wash arm then take of cover...should be torx head screws to get to impeller.
Nov 06, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Nov 03, 2007 | Maytag 24 in. MDB7650AWS Built-in...
Jet dry not draining no clog as far as i know
i needed all your all your serial num its important 17
Nov 30, 2006 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB7650AWS Built-in Dishwasher Logo
2,675 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
