Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Speakers where is the port hole for them
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to look in at the back of the
cpu there is a port of hole of a speaker
Posted on Oct 30, 2008
What port on the back of the hard drive do I plug the durabrand uc280 USB powered speakers into?
Hi Missy
You don't plug the speakers into the hard drive.
You should have two cables or wires
a USB cable, which you want to plug into any open USB port. the USB cable will not plug into any port other than a USB port, so just find any open one.
The second wire should be a male 3.5mm stereo jack plug.
If you have a desktop computer, look on the back for a round green hole that the stereo jack will fit into. There may or may not be a symbol of headphones. You may not have a symbol or colored hole, in that case find the two or three holes that the plug will fit into, then turn on a program that should have sound, then plug the stereo plug into each of the holes until you hear sound. If you hear no sound no matter which hole, check to make sure you do not have the sound muted.
If you are using a laptop, look for the hole with the headphone symbol.
Hope this helps.
Jul 31, 2011 | Computers & Internet
I got some mi speakers and i dont know how they plug into my computer
Hi there.. Is your computer is a laptop or desktop? If it is a desktop locate the dark color green port hole on the back of your computer and plug in the speaker after you plug it in turn on the speaker and play some music. That should work the same thing with the laptop but mostly it's located either left or right side of the laptop and same dark color green port hole. Try it. God Bless!
Apr 20, 2011 | Computers & Internet
No power of my SC-HC3
I have good and bad news for you. If you have a UK power plug for 250VAC (odd shaped three-pronger), then you should be able replace the small 5 Amp fuse inside the plug (jack) head of the power cord and it will work just fine. That's the good news. If your like the rest of us on the planet, then there is no fuse to protect the power supply from line voltage spikes. Some component of the power supply has been fried... there is no internal fuse as I torn the thing apart, including the transformer compartment looking. Rumors elsewhere talking about an internal fuse in the SC-HC series of Panasonic CD/IPOD players are not true. I had read several myself and believed them to be true, so proceeded with dis-assembly. THERE ARE NO USER SERVICEABLE PARTS INSIDE THESE PRODUCTS. It is not worth repairing. I am an engineer and can tell you that the best thing you can do is salvage the speakers with the grills and make yourself a nice pair of cube bookshelf speakers with them. A pair of 1500Hz crossovers (or thereabouts) and a a pair of screw-in speaker terminal strips from Radio Shack, carpenter's wood glue, wires (red & black by convention), a low-wattage soldering iron, electronics solder, and some planed wood is necessary. The original design is tuned port, bass reflex so to obtain the same sound quality you will need to cut a round hole with an Area of 17.7 cm2 in the speaker box cabinet back. For those using inches, it's 2.54 cm/inch; divide by (2.54)x2, so you can understand the port hole is not very large. You should place the port hole on the back as in the Panasonic design as making the speaker cabinet larger will require a different port size to get the optimum 50Hz tuned bass punch from the speakers. Just cut the wood to form a rectangular cube. Make holes in the front precisely so the speaker grills can clip in around the speakers, make your tuned port hole in the back, and make a small hole to pass wires from the crossover inside to the speaker terminal strip on the outside ON THE BACK (usually near the bottom). You will need to use a hole saw (cheapest type uses an electric drill attachment) or a jig saw to cut holes into the front of the speaker box to insert your speakers flush against the wood face (make a paper template and trace the round circles onto the wood). Connect each speaker to the proper part of the crossover; i.e., tweeter and woofer cone with your wires and solder all the connections, finally, screw the speakers into the fronts with wood screws. Use carpenter's glue to glue the wood pieces together. If you have the time and the inclination, this makes a great family project to introduce recycling concepts too. These speakers will be good for surround sound applications (rated at 40W RMS) or simply used to connect to a small sound system. To use it with a PC, you will need to buy an a stereo mini JACK and carefully solder the wires you extend from the speaker terminals: join the two black wires together (one from each speaker black terminal) to solder onto the long side inside the stereo mini JACK and solder each of the red wires onto a separate prong of the two remaining. This will provide stereo sound by inserting into a PC's headphone plug. For information on how to design and build speaker cabinets, Radio Shack has an excellent (very cheap) paperback on the subject. Hopefully, this gave someone an idea.
Feb 27, 2011 | Panasonic SCHC3 Micro HiFi System Speaker...
I don't get d true bass quality from my car system...
Firstly, If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches.
May 14, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What size enclosure is recommended for 2 10" kenwood tornado subs?
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 11 inches x 11 inches x 11 inches
Apr 19, 2010 | Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER...
What is the best box to get for a pair of cvr 12 for my yukon
Mar 21, 2010 | Kicker CompVR Loaded Sealed Boxes...
Which speker box should i use for alphasonik
Mar 15, 2010 | Alphasonik Mayhem PSW912 Car Subwoofer
Connect Creative 5.1 A500 speaker system to Phillips DVD 3256
Just buy two connectors(shown above). Its having two holes upside.
1. Connect the connector to one hole of the other.
2. Connect the audio cable to the dvd.
3. Then connect the connectors to the other side of the audio cable.
4. Lastly, connect the three stereo output cables of the Creative speakers to the three holes of the connector simultaneously.
I have tried this at home with my Creative Inspire M5300 speakers and philips dvd. All the five speakers are working.
Rovan C
Jan 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
I am a computer dummy...How to I connect speakers for sound like music in my computer?
The end of your speakers should have a green plug, on the back of your computer there is a green port. Insert the green plug into the green port. If you have a power cord for your speakers you need to plug that into the wall.
Please rate my answer, and good luck.
Jan 20, 2009 | Computers & Internet
5.1 GMX ProMedia Issue
The jacks on the back are probably for an amplifier output and you probably have had the speaker wire stripped too long possibly shorting out the amplifier as this is a common problem, if not stripped too long it may have just failed, also you need to check by unplugging from back of computer and hook up to a walk man or something with a headphone jack, see if still dead, might also be the cable from the computer to the speakers. Good luck. :-)
Jul 06, 2007 | HP ProMedia Computer Speakers
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
29 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
