Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Wild Thing-(18")hard starting
Hi
Owned chain saws for about 30 years...Bought this one and had a hard time starting it...once it is started it runs fine...had a mechanic friend of my whom also owns one try and solve the problem...While starting up the unit,
the rope action is stiff and takes alot of pulls to get it going. Once it is warmed up it is fine. Thanks for any help.
  • 1 more comment
  • collards Nov 01, 2008
    same exact problem
  • rocky62 Nov 07, 2008
    My chainsaw won"t start. Could it be fuel mixture? Has spark from plug.Never did start easily is only about 7 mo. old.
  • crowefamily1 Dec 01, 2008
    I bought my 18" wild thing in 2007 used it off and on Saturday I was out cuting wood for the fireplace and it died, I cranked it right up it ran for a few minutes and died again after I idled down to move the log and go to another now it won't start I checked the plug and filter and they are ok. Any ideas? buysaleortrade@yahoo.com Thank You for any help.
I own the Poulan Chain Saw the Wild Thing. Replaced the spark plug and fuel filter and made a fresh batch of gasoline mix and I am still having a hard time getting it started. I had the exact same problem last fall. Repair shop told me it was flooded. If this is the case how do I resolve the problem. I took the plug out and it was dry.
Thanks,
**** Hansen
Posted on Nov 03, 2008
My sparkplug is good. HomeDepot started right off though. I took it back home and had to crank it 30-40 times. The line is real stiff and only pulls out a short piece.
Posted on Nov 02, 2008
  • 14 Answers
You may want to check the 2-nuts holding the carb to motor. At this saw mill, we have a little Poulan used everyday. About every 2 or 3 months, it will get hard to start. Usually it is sucking air around the rubber mount holding carb in place.
Posted on Nov 19, 2008
I wrestled with mine for two weeks, new, out of the box. It turns out that the spark plug had a hairline crack in the insulator. Champion.
Now after using it a good bit, it is hard to start again. It either has dirt in the carb orfice or the diaphram is old and non-pliable.
Poulan chain saw wild thing will not start
simple things first
right fuel /oil ratio in tank ?
aircleaner not blocked off with sawdust?
stop switch set to correct "run" position , switch not broken damaged ? chain brake set ?
choke set correct to start ?
primer bulb working correctly , fuel is visible inside bulb
Apr 30, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 18" Gas chain saw starts no problem but it runs for maybe 30 sec. then stops each time. I changed the core same thing.
Do a tune up. It is easy. Just take out the carb and clean with any commercial carb cleaner nad change the spark plug.
Oct 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin: I own a Wild Thing 18". I don't believe the auto o...
Remove the bar and chain. Start the engine and observe the side of the engine where the bar fits to it. The oil port there should ooze oil out when the engine runs fairly fast. If nothing, then investigate the filter within the oil tank for plugging, the oil line from the tank to the pump for any damage or decay, and the oil pump itself. The pump should discharge directly to the port that the bar receives. If oil did ooze out of the port on the first test, then clean the oil passages in the bar end--two small channels that run from each large hole out to the chain groove on each side. Clean the entire chain groove. Check the sprocket on the other end for fairly free turning--oil it's bearing. Examine the chain carefully--if it got so hot that it turned the teeth blue--replace the chain, it has lost it's tempering. Assemble bar and chain--adjust the chain so that the lower side doesn't droop from the bar, and you can turn the chain by hand. The teeth cut toward you on the bottom run. If the old chain is being reused, sharpen the chain carefully so that it cuts quickly without undue effort on your or the engine's part. Hope this helps!
May 17, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Runs but choke still close, or pull out postion
You can start with the choke closed but you must open it up once it start running.
Sep 25, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing chain saw rope came off
by the time it would take to tellyou ,you would be better to take it to any small engine work shop. it is not difficult but it is to explain
Jul 20, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Feb 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing will not start
check the fuiel filter in the gas tank, it might be dirty, or need to be replaced
Jan 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
833 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
