Question about Microwave Ovens
Need the code to reset programing on microwave
Microwave is not working proper can not get it to come on or set the timer.
Timer will not let you reset it if you make a mistake when entering the time
Posted on Jan 25, 2010
    President:
  • 2,712 Answers
Try this first: Unplug the microwave from power source for about 15 minutes and rreplug and see. Make sure that the wall plug is viable. If not, try using a different outlet and see. If both fail, then you may need to get the microwave serviced.
Posted on Oct 30, 2008
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
The timer doesn't work right.
Are you programming it for 2:00 or just pressing 2, then Start?
Try resetting it by unplugging it for a couple of minutes, plugging it back in, then setting the clock and trying again.
Jan 08, 2013 | Maytag MMV5207A Microwave Oven
Hi, I have a Kenmore 87103 microwave and it has started acting up lately. When I place something in the microwave and set the timer, the timer counts down however the microwave doesn't work (no sound and...
Mine also does the same thing however I only need to lift the door upwards slightly (after it's closed) and it engages the High Voltage Transformer, thus working as normal.
Once you know that, you can get it to work every time. I beleive the clips on the door don't properly stop latch in correctly and the safety feature keep the microwave from acutally turning truly "ON".
Nov 28, 2010 | Kenmore Microwave Ovens
The microwave stops after 59 seconds.
hello,
what this means is that the timing of your oven have been program on 59 seconds mistakenly
what you need to do to correct this problem is that you will have to reprogram the timing by resetting the time program on it by clicking on the setting button and type in the new timer with this the problem is solve
Good luck and thanks for using fixya.
May 29, 2010 | Sharp R-1480 Microwave Oven
Timer runs fast, plus no heat Maytag MMV1153BAW
No... you are not in a microwave induced time warp...
Your microwave oven needs a "reboot". The same thing happened to me.
Unplug your microwave oven, wait about a minute (more or less), plug it back in. Try setting/running your kitchen timer, boil water, etc. Your timer software on the microwave should be reset.
Jun 14, 2009 | Whirlpool MH7135XE Microwave Oven
Timer descends very quickly
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Feb 01, 2009 | Maytag MMC5000 Microwave Oven
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Apr 06, 2008 | Microwave Ovens
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Microwave Ovens Logo
151 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
