Question about Kenmore 15892 Built-in Dishwasher
DW won't drain and "lock" light is stuck "ON"
Aprox 3-4 yr old Kenmore 15892 worked perfect (?) since new. Few weeks ago would not drain. Experimented with front elctronic controls and pressed "cancel" and held a few seconds. DW then drsained out remaining rinse water. All OK until yesterday when "lock" light came on and stayed on when trying to start. Never even noticed that light coming on before but now washer does not work at all. Light won't clear by pressing "cancel". If I hold for 10 seconds, "quick rinse" lights and blinks, but then "lock" lights back up when cancel is released. No lights when door is ajar. Too many other project underway for this thing to break down now. Help?
  • 2 more comments
  • Joseph Horvath Sep 10, 2006
    My board is a bit different than either, with six cylces reading:
    "anti bact" "pots pans", "norm wash", "china/gentle wash", "time saver" and "quik rinse" and an options group reading: "hi temp scrub", "sani rinse", and "air dry" followed by "delay", "start" and "cancel". The lock light is just under the "air dry" button. I tried what I thought was the closest match to those buttons you referenced and still no go. Given that the presumption is that it's a board issue, my next step is to turn off the breaker, check the board for contaminents and clean with an electronic parts cleaner. I'll post back what I find later today. It can't be worse than when I cleaner cat yak from my PC's keyboard. Disassembled, washed then rinsed with distilled water, blotted dry and let air dry overnight. Presto!
  • Joseph Horvath Sep 11, 2006
    OK, Catriver,now I feel silly. This is not exactly like a PC keyboard internal. Opened it up and found that the keypad is a sealed ribbon unit. Probably can't remove without destroying seeing that it's applied with doublestick tape. Also nothing to get gunk on like a board, which that area is very well protected from front spills, steam, etc. Going to reassmeble, try to reset again and if still stuck, will order a new keypad overlay. At least opening it up I got the part number. Thanks. Will post back when operational if new overlay fixes. One remaining question is the incomplete drainage. Why didn't it ever finish? Doesn't that seem more like a pump or solenoid problem?
  • Joseph Horvath Sep 15, 2006
    Pressing the air dry button for 5 seconds DID clear the problem and "lock" light. I was about to start testing individual components today when I saw this solution on another site and then here. The thought of a $120 panel overlay was sickening. DW seems to be working now. So far I just ran the cancel/drain cycle but will do a full test later. Washing dishes by hand bites! Thanks for your follow-up response! I greatly appreciate this forum and the help. Joe
  • Joseph Horvath Oct 30, 2008
    catriver- Here it is two years later and the same problem occured, One difference is that the "CLEAN" lisght is blinking too.
    Washer was started, but only began cycle, then had a blinking "CLEAN" light. Blinked 7 times, then paused, then 7 times, paused, etc.
    Came back to this board and found the previous recommendation. I'm sorry I failed to post back. In the end, 2 years ago, I replaced the control board, for about $100
    Today, I started by pressing the HI TEMP SCRUB, then AIR DRY, then HI TEMP SCRUB, then AIR DRY. No luck. Then tried pressing and holding the AIR DRY button for 5 seconds, until red "LOCK" appeared. Then I again tried pressing HI TEMP SCRUB, then AIR DRY, HI TEMP SCRUB, then AIR DRY. The board lit up like a Christmas tree. All the lights lit, then NORMAL WASH lit up anad a time of 8 minutes, then a cycling sound, "7 mintues" and a a short cycle light, "4 minutes", then "3 minnutes", "2 minutes" all the while sounding like a short washing was occuring. At the end of two minutes, it shut off. No blinking lights.
    After coming to the PC and keyinig all that happened, I went back and started a new wash cycle, selecting "ANTI BACTERIAL" ( why would anyone NOT choose this ??), then "AIR DRY". It started up OK. Will see after a while then add more to this post.
    Meanwhile, I thought it should be noted that with this new control board, when starting a wash cycle, after pressing "START", instead of a time displaying in the window, it now shows a single LED bar, like a clock hand, blinking in a 12 o'clock, 3 o'clock, 6, then 9 o'clock position, continuing to go around for what seems like the first 20 minutes.
    BOTTOM LINE - after running for a short while, we're back to square one. The machine stops running shortly into the wash cycle and the clean lights blinks seven times, pause, then seven times, repeating continuously.
    Kenmore model 655 15892 100
    President:
  • 878 Answers
Joe, see if you can reset the board by pressing heated dry-normal-heated dry-normal..(new board). Old board is high temp wash-air dry-high temp wash-air dry. See if it goes back to normal. If not you probably have a stuck or shorted keypad on the overlay..not the board. Catriver...post back
Posted on Sep 10, 2006
  • Ron Marek
    Ron Marek Sep 10, 2006
    Joe, press and hold air dry for 5 seconds, does the lock light come off? Catriver..post back
Soapy water won't drain out
Many times soap can get inside the DW from the sink. This is bad news. The pump doesn't like it. You may have to run several empty cycles to get rid of the SUDS. If that doesn't work Look for other problems.
Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Jan 04, 2014 | Kenmore 24 in. 15173 Stainless Steel...
Hi I have had this intake/drain light come on in my Miele G851 SC dishwasher. I followed the recommended instructions in the manual: - clean triple filter, drain pump, and non return valve - check...
Is their debris in air gap or in the bottom of the DW, where the drain is screened? Look for obstructions.
Good luck.
Oct 25, 2013 | Miele Dishwashers
Won t drain
Good luck.
Oct 22, 2013 | Bosch Dishwashers
I have a Kenmore washer model #110.20022011. The other day it did not spin out all the way, now it will not start at all. The fill light and lid lock light comes on, but it does not start. Water and...
A friend of mine bought a Kenmore washer model 110.20022013 a year ago. Now washer stopped in the middle of washing and a clicking sound starts, and not washing or rinse or draining
Aug 22, 2011 | Kenmore Washing Machines
2004 Saab 9-3 Aero. replaced fuel pump aprox four month ago ( @ Aprox 100,000 miles), the last two fuel fills I have smelt gasoline in and around car (no visable leaks). Check engine light came on 1 week...
While a fuel filter won't normally cause the check engine light, it could cause other errors that would trigger the error light to come on.
Since fuel filters are easy to change and not very expensive, I would change it and see would happens. But you might also want to run a pressure test on your fuel pump also.
Jul 08, 2011 | 2008 Saab 9-3
Startup
dear sir.
"checking disc comes up" this message is hard disk message and it's showing becoust missplase of harddisk thru yr laptop scoket if u know bout laptops u need to plug off then reconnect yr laptop harddisk otherwise contact system wonder near u.. it's help u.
Jan 01, 2009 | Computers & Internet
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Blinking quick rinse and lock on lights
Try holding down the "lock" button.It may be the way to unlock the problem.
May 26, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
9 yr.old GE profile top/bottom refrigerator
There could be many things that cause these symptons. Defrost timer not working, bad door seals, or lack of freon. It may be less expensive to replace the frige than repair it.
Oct 20, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 15892 Built-in Dishwasher Logo
350 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
