I try to bake and the f3 code comes up. It starts beeping, I have to hit on it. Then it might come on for a couple of minutes. Then it comes on again.. I have already replaced the inside temp sensor. I have a kenmore 911-4552090.
Hi pickerrauto7,
The f-3 code code indicates a bad or open temperature sensor in the oven. It is the little metal rod in the top of the oven about the size of a pencil.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
You will have to remove the back panel of the range to correct the problem. The temp probe is held into place with two 1/4 inch screws. If the connections are good then the probe is bad. Good luck to you on your repair. I am sure this will FixYa. Please dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
i have the same problem and just replaced the oven sensor. i will pull the over out and check the connections to the control board. hopefully that will be a fix. stay tuned ......
