Question about Dishwashers
Water will not go into dishwasher
It's a kitchenaid and I just replaced the water inlet valve. It appears and sounds like it's going through all the motions but when you interupt by opening the door, the usual water splashing sounds are not there. The wash arms are not moving. Apparently some water gets in because it's damp and some pumps out. Any advice as to what next, I would appreciate...Steve
    President:
  • 1,314 Answers
The first thing that happens when you trun on a dishwasher is it pupmps out then it fills if you open the door and see no water its not filling after the first pumpout now inside is a dome float that sits on top of a safty micro switch to prevent overfill pull the kick plate and see if that float rod is engaging the micro switch if not or the switch is bad it wont fill
Posted on Oct 30, 2008
My old KitchenAid KDS-16 dishwasher is making a loud, high-pitch, metallic sound but it still appears to be operating OK.
There is a fan blade on the top of the pump shaft. IT is loose. They are pressed onto the shaft. The only thing you can do is replace the motor or the whole machine.
Sep 08, 2017 | KitchenAid Dishwashers
Water will not enter my Kitchen Aid dish washer.
see this causes and fix it:
the water inlet valve, where the water is coming is defective, test it and replace see the diagiram
2)float switch, can be open or defective, is located in floor of the machine, test it and replace.
God bless you
Jul 10, 2012 | KitchenAid Dishwashers
The Water inlet valve # 8531325 let water run outside the dishwasher. After removing the valve I found a small ball of contamination inside and removed it. It now works with out spilling water. Do I still...
IF the valve stops and starts water flow correctly, no you would not necessarily have to replace it. The valve should have an inlet screen to keep this from happening again..
Feb 14, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Cycle runs but dishes are still dirty. No water.
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
Jul 03, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
My KitchenAid Superba (whisper quiet ultima) started to leak out the front when it is running. Is this an easy repair or should we think of replacing the dishwasher? BTW - we love this dishwasher!
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Mar 18, 2010 | KitchenAid Dishwashers
My dishwasher is not washing the dishes it acts like there is no or not enough water coming out, the supply line is new and good water pressure going in just not coming out
Water inlet valve not opening all the way. Water should go up to about the heating element. Let dishwasher fill when it goes to the wash cycle open the door to stop it and see how high the water level is. The water inlet valve may have a screen on it that you can clean out. If the water is not high enough and the water inlet is not clogged up replace the valve. If the water is high enough several other things to check.
Feb 26, 2010 | KitchenAid Dishwashers
Dishwasher makes grinding noise during wash cycle (after pre-wash). noise persists for 15-20 minutes. It seems as though the inlet valve doesn't open during this phase of the cycle. adding water to the...
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Nov 19, 2009 | KitchenAid Dishwashers
Dishes not clean
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwashers Logo
190 people viewed this question
Top Dishwashers Experts
