Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer cartridge message says replace the following cartridge(yellow) i tried 4 diferent ones and it still gives me message. I uninstalled and reinstalled software, called hp, went through all their lame troubleshooting most of which i had already done. It still will not work.
  • Anonymous Nov 14, 2008
    Tells me to install magenta, but I have installed a new one and it still will only print in black. What can I do to get it to print in color again?
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
may be the cardridge install not
place properly? try to remove
and placed it properly!!!
Posted on Oct 30, 2008
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
Replace yellow ink but machine says no cartridge
When you get the "no cartridge" message it's because one of the sensors does not recognize ink in one of the cartridges.
First open the ink cover and read the LCD screen.
The LCD will tell you which cartridge is having a problem. You should change which ever cartridge is telling you there is a problem.
If the LCD says there is a problem witht he yellow (which you just changed) then follow the below steps.
1. Unplug the power to the printer.
3. Close the ink cover with all the inks removed.
5. When the LCD says "ink empty" you will reinstall all 4 ink cartridges.
Thank you,
Mar 29, 2010 | Brother MultiFunction Center MFC-440CN...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Installed new yellow print cartridge for HP printer, prompts to install new cartridge but my ink level says full
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
My Brother DCP135C printer won't read my new cartridges
Do a hard reset on printer to restore factory defaults.
Sep 20, 2017 | Office Equipment & Supplies
Lexmark x 3650 change ink cartridge but it still gives a message(
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Dec 22, 2008 | Canon MX300 Office All-In-One Printer
Display says I am out of yellow,
Hi, since you've already replace the yellow ink cartridge for several times and its not recognize. Your printer might have a defective printhead. You may take your printer to the nearest HP service center in your area so that they can look on your printer further.
---->> Tirzo
Jun 04, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
HP Photosmart C6180 All-In-One InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
