Question about Tools & Hardware - Others
Where can I buy parts for my Hobart?
Where can I buy a new cable because my old one got rotted for my Hobart H 600 Dough Mixer? I've been looking around to get a new turn on and off switch as well. Thank you.
    Sergeant:
  • 359 Answers
The easiest fix for the cable would possibly to go to a good electrical supplier and simply purchase a length of S O cable and a plug to match the one that is on machine , another words make your own this would probably be much less expensive as well s.o. is the cable most all equipment comes with , as far as the switch if you take the old one they possible have a oem match or can get it for you , if this does not work for you i can give you the address of a restaurant supply house that might have a supplier to them that these parts are available from , but would cost more that my idea , if you remove the switch be sure and make diagram as to how it was wired
Posted on Jan 12, 2009
When mixing pizza dough in hobart se 601 mixer the dough hook stops under load any suggestion
Depending on how old the mixer is, I would check the belts (if it is belt driven) to the planetary gears. If it is not belt driven, it sounds as if the motor is faulting out. I would replace the motor brushes first before spending money for a new motor. This may not be an intelligent question but I have to ask, are you overloading the mixer? A 12 quart mixer will do fine with cake batter but when you mix pizza or bagel dough, the moisture content is much less and it is equivalent to cement. Sorry, I had to ask because I have seen this before. Good luck and I hope this helps.
Oct 20, 2014 | Hobart Mixer Only, Planetary, Bench, 12...
Hobart h 600 mixer dough hook keeps coming off during operation. What would cause this
Take a look where the agitator pin engages with the dough hook.
Either the agitator pin (sticks out from the agitator shaft) is worn out or the groove in the dough hook where the pin should sit has elongated and worn. Either pin replacement is in order or new hook is required...possibly both.
Jul 04, 2014 | Food Mixers
What is the correct dough hook to get for my 'OLD' A200 Hobart?
Check with your local Hobart office.
www.hobartservice.com Click on "Locate an Office" and enter your Zip.
Jan 20, 2010 | Hobart A200 Stand Mixer
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Jan 05, 2010 | Hobart A200 Stand Mixer
Having a hard time removing the dough hook on the h-600.
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Dec 03, 2009 | Hobart H600 Stand Mixer
Where to buy dough mixer parts please many thans.
the best bet is any hobart office in your area,i have seen many mixer damaged because of non-hobart parts installed in them
Sep 23, 2009 | Hobart D300-6036 Mixer
Contact overload for h600 3 phase mixer
I'm a hobar tech and repair these often.The problem is the overload contacts are opening so the motor doesnt burn up.I know the mixer is old and the overload has weakend over time or simply the mixer is being overloaded with too much product.Did you just get this mixer?change the recipe?mixing pizza dough and adding ice?Any new employees if it's in a buisness?
Mar 19, 2009 | Hobart H600 Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
Hobart N50 Tripped
The reset button is to protect over amping the motor. The N-50 is not a very strong unit, (commercially), but you won't break a gear. If you overload the unit, you'll either trip the overload (reset button), or you will break the taper pin that attaches the planetary to the center shaft.
If you're looking for a small commercial unit, and you're in the US, look into the 10 qt Precision Mixer.
Apr 04, 2008 | Hobart N50 Stand Mixer
Dough mixer not working at all
it sounds like the mixer was overloaded and therefore broke a shaft,gears or sheared keys.
Oct 27, 2007 | Hobart D300 Stand Mixer
Tools & Hardware - Others Logo
80 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
