Question about RCA F25649 25" TV
RCA TV Of late my RCA TV has been behaving funny, first it start by switch on by itself and now it is switching off every 3mins. TV at times switches its self on in the middle on the night and even changes channels, at first i thought maybe someone with the same make and model is using their remote and thus affecting mine but i dont think so. what can i do
    President:
  • 3,130 Answers
First try to take out the batteries out of the remote and see if its activatibng the TV set. if its not then there are probably bad micro switches in the front of the set, or the microprocessor could be going bad, or the remote sensor is acting up
Posted on Sep 09, 2006
SOURCE:
What would cause a model number 37wd12 to turn itself on and off at random.
Is the remote doing it?...remove the batteries from it and see if it still does that
Feb 07, 2018 | RCA L37WD12 37 in. LCD HDTV
My television is just over 2 years old and it started that it would switch itself on and off 3 times before it would stay on and it was randomly switching itself on if I didn't need it to. I phoned the...
there are four capacitors on the power board that the switch is connected to that are failing, eventually they will go completely and the set wont turn on at all. You need to replace the capacitors and the problem will be resolved. Find someone to replace them for you, they will cost less than £4 GBP to buy if you can do it yourself (or someone you know) probably over a hundred to get an engineer to do it
Mar 01, 2011 | Televison & Video
Turns off and on by itself
You have bad switches behind the push buttons on the front panel. RCA had a problem with there switches sticking internally. Change them all at one time to avoid later problems.
Oct 14, 2009 | RCA TruFlat 27F520T 27" TV
RCA model# P52937SGEO35C5O6E---PTK195M4B Home theatre guide+gold
the buttons switches are leaking more than likely this a comon problem in a lot of tvs they start leaking and send a voltage signal to the ics and tv will start doing funny things. Anyway need to replace these switches probley about six of them in all they are mounted on a board behind where you push the power button. Should replace all just to be on the safe side.
Feb 15, 2009 | RCA F32648 32" TV
Switch starts switching back and forth between computers itself
There are no firmware updates for the GCS62 also the KVM appears to not have a firmware upgrade port. If the KVM is auto-switching have you tried hitting the ESC key or Space Bar? That should stop the auto switching.
Feb 12, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
RCA 27V412T
ok! change all tact switches! your tact switch has abnormal resistance! thats why your tv is changing system!
Oct 01, 2007 | RCA F27669 TV
TV Akai CT29X4AV
Have tried checking if the Power Plug is fitting tightly in the Power socket? Could be that it is loose?
May 27, 2007 | Akai CTS2550 25" TV
RCA F25649 25" TV Logo
82 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
