Question about RCA DRC8052N DVD Recorder
Video link to tv
My unit was working fine but now only the audio works. the video portion doesn't come on the screen other then a rastor that looks somewhat like a horizontal hold problem. sometimed after turning it onand off repeatedly, I can ge a almost black and whihte picture but still angular and distorted.
Gyi51@ardmore.net
I had a very similar problem and with mine it must have been a software issue. I went into the setup and did a resotre to factory defaults.... and the problem was fixed.
Not sure how it happened, but now it is back to normal.
Mark
Posted on Nov 19, 2008
Panasonic VIERA TC-L42U5 42-Inch 1080p 60Hz Full HD LCD TV (Screen doesn't work)
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 01, 2017 | Panasonic Televison & Video
JVC 52 inch tv, about 8 years old has sound but no picture and WE CAN read the cable guide on teh tv screen......please help! Thanks so much!
Try another input on the set, if you have on screen display set is working to some degree, also try to unplug set and or box or other gear hooked to it for a while and power back to allow all to reboot or try to===problem is NO video or no rastor if menu comes on screen. Also please check which input the set is currently on......
Oct 30, 2012 | JVC Televison & Video
Apple tv doesn't work when hooked up to denon 2311 receiver. Apple tv is turned on but tv screen displays the word
http://usa.denon.com/documentmaster/us/avr-2311ci_lit527.pdf
This is the link to the probable box in question. The Apple TV needs to be connected to HDMI input port (pick on of the six available). Follow setup instructions.
Jun 08, 2012 | Audio Players & Recorders
I have been playing DVDs without problem for several years on my RCA 20F510TD 20 in. TV/DVD Combo. Now when in the DVD mode, with a disk inserted, the screen comes up with no disk found. What can I do
NOT much you can do---It is a bad optical unit inside the DVD unit---they do not see parts----only the complete DVD portion----much cheaper to go out and buy a DVD player and connect it to the audio and video jacks this unit should have.
Mar 22, 2012 | RCA 20F510TD 20 in. TV/DVD Combo
No video signel
Check your hook up to set and connect something to a different input to see if it works.
Set has sound? rastor or light on screen? On screen menu works?
Mar 15, 2012 | Toshiba REGZA 32WLG66 32 in. Television
I am trying to hook up a Panasonic Blu Ray Player to my Toshiba flat screen TV. The red cable which is the audio cable doesn't seem to make the audio come out on the TV. I tried every single slot on...
They print manuals for these things.
Have you looked at them?
The specific products you're inquiring about are not showing in your post. Name the makes AND models first, then we'll look for the manuals. Then (maybe) find a solution. You might find it them the manufacturers' support sites or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
The standard color codes for analog audio are Red/White = Right / Left; Yellow = Composite Video.
Single coaxial or optical SPDIF cable = digital stereo or multichannel audio
Red/Green/Blue = Hi-Def component video
HDMI can carry multichannel digital audio and Hi-Def video from a source to a TV
May 15, 2011 | Toshiba Audio Players & Recorders
How do I escape from an input screen back to watching satellite tv? Screen reads first please connect all signals and antennas to jacks and terminals on the back of the tv then press the channel up key...
Looks like your set is not receiving the signal from the sat. receiver. Make sure that the audio/video cable is in good shape and connected correctly, then select the correct input on your tv. If that doesn`t work try to connect a dvd or vcr on the same cable, if that is still no go then you may have a bad audio/video cable or there is a problem with your tv set. If it does work(dvd/vcr) then you`ll have to check your satellite receiver. Hope this help. Good luck
Nov 24, 2009 | Televison & Video
No video on tv monitor
To permanently fix the problem you have to send the unit to a programmer. A quick fix would be is to physically do it in your TV. While your Direct TV satellite receiver is ON, press the "TV/Video" or "Source" or "Input" button in your TV until the video will appear in the TV screen. All the TV has either one of this button.
May 18, 2008 | Universal Remote Control MX-3000 LCD...
60" plasma TV video turns off
I just unplugged the TV for a minute and then plugged it in again. It works fine.
Apr 05, 2008 | LG 42PX5D 42 in. Plasma HDTV
Partial Screen Display
Problem in the LCD back panel board. check the interface unit or ADC unit, also check the video clock pulse. one section is not working.....
Oct 09, 2007 | Dell E173FP 17" LCD Monitor
RCA DRC8052N DVD Recorder Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
