Question about Emerson EWL20D6 Television
Is my tv digital or analog?
I have an Emerson Model: ewl20d6 Will I need a converter in Feb 09?
Thanks you
Darleen
  • s_darlinc Oct 30, 2008
    I went to the info page recommended and under key features it says
    "EDTV-Ready Television", but under display capabilities it says "
    EDTV-Ready - Requires separate receiver to view EDTV signals."
    Does that mean it just needs an antenna (that I am using now) or a converter box.
    Sorry for the questions but I am an old natural blond and get confused easily. LOL
    Thanks for the help
    Darleen
  • Anonymous Dec 26, 2008
    philips 25ps40s121
    Genius:
  • 1,447 Answers
Hi-
This is a digital TV, you can find info HERE
Posted on Oct 30, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Oct 31, 2008
    HI
    You will need a receiver so that you can view digitalized programming. You can get one when you subscribe to dishnetwork or direct tv. But over the air antenna will work as well with it.
    Hope this helps
I have a emerson model EWL20D6, after adding a TV antenna it tells me no tv signal. Do I need a converter box?
possibly but perhaps just an autoscan for channels and having it set to the proper input . in the main menu
Sep 23, 2015 | Emerson Televison & Video
What cable do I need connect my Emerson EWL20D6 to my laptop?
This TV can't understand a laptop signal directly (for most laptops - there are some computers that have a TV out option). The EWL20D6 has S-video, component and composite video inputs. Your best picture will be to get a VGA (RGB) to Component Video (YPbPr) converter with a 3.5 mm to RCA L/R audio cable. See this page for some idea of the available converters: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html . The VGA to component video cable is meant for projectors that can interpret the RGB signal, not TVs.
If your laptop has an HDMI port, you will need a different type of converter.
Once you have the correct hardware, you will need to make sure that the external video port is active on your laptop. For some machines, you may need to enable this in the BIOS first (press Esc, F1, F2 or F10 (depending on the computer) on bootup to get to the BIOS - it may take a few tries to time it correctly). Then turn off the TV and computer before connecting the cables. Then turn on the TV and set it to the desired input before turning on the laptop. Then set the laptop to send the video signal to the external monitor. (On my Win7 laptop, I right-click on the Desktop and select Graphic Properties. Then set the desired display (laptop screen, external monitor, both) and click Apply. Then press OK when you see the confirmation box on the now active screen.)
The Emerson EWL20D6 was manufactured by Funai for the Emerson line. Thus the manual is available here: http://www.funai-corp.com/support/manuals.aspx . Manuals are listed in alphabetical order. (If you use the search function, leave off the brand name.) The direct link to the manual is: http://www.funai-corp.com/6pdf/om/EWL20D6.pdf .
I hope this helps.
Oct 17, 2011 | Emerson EWL20D6 Television
Analog to Digital converter
Ur tv a LCD or Plasma tv?No,LCD and Plasma Tvs have a Digital tuner inside the tv to recieve free air DTV.Not require a Digital coverter box,if u have a LCD tv or a Plasma tv.U must have good antena thought like a roof or a digital antena,so ur tv picture don't cut in and out very often.
May 29, 2010 | Olevia 332V LCD TV
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
Is this tv ready for digital tv feb 17 2009
Thanks but we found the answer,the manual say standard,not didital. thanks for your help
Jan 18, 2009 | Emerson EWF2704 TV
Does the Emerson 20S5B have a digital or analog tuner?
it is a digital system, and yes vhs anolog. and it is HD ready.
hope this helps.
daniel.
Jan 09, 2009 | Emerson EWL20D6 Television
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
Digital tv not picking up digital signal??
According to the manufacturer, the EWL20D6 Television is not digital ready. If that is the case then you will have to use a converter box in order to receive the digital channels.
Dec 20, 2008 | Emerson EWL20D6 Television
Will I need a converter box for my Durabrand TV, Model DWT2405?
I'm sorry, but a DWT2405 is not digital. You will need a converter box.
Nov 10, 2008 | Durabrand DWT2405 24" TV
Do I have an analog or digital TV ?
You have an ANALOG set. After 2/17/09, you will need to be connected to cable, satellite or get a convertor box to watch this set.
Mar 24, 2008 | Televison & Video
Emerson EWL20D6 Television Logo
423 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
