Question about Microwave Ovens
Panasonic NN-S952WF Microwave
Then microwave lights, fan and carasol start running when I open the door. I do not think the microwave is cooking but I won't chance it. Otherwise it works fine. What can cause this?
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic microwave no working at all
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Dec 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave shuts off after 2 seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer (above) to get it fixed free.
Posted on Jan 03, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Setting time on Panasonic NN-CD748B microwave
Panasonic's UK site is here and you can choose Support, then search for spares, servicers, downloads and contact info.
Posted on Jan 09, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic microwave nn-s963bf making grinding noise
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can
order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Mar 06, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Have had Panasonic microwave NN-S753 several
Thanks for that ID number. That's a big help.
Now, looking at the schematic, it's clear that you would have a shorted primary latch switch (top door switch) or that switch's mount is damaged.
For safety, disassembly and diagnosis of door switch trouble, see my generic files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Mar 17, 2009
PANASONIC Microwave Inverter #NN-SD697S. Everything works except the START button. Works sometimes, and not other times. Checked outlet, all was good.
This is either the door sensing switch (most likely) or a bad membrane switch [start switch] (that's what Panasonic calls it) on the touch pad. The contacts on the door sensing switch can be slightly contaminated and not read "zero ohms" to the control PCB. The control board thinks that the door is open and it will not allow the cook cycle to start.
Sep 11, 2013 | Panasonic NN-S251 Microwave Oven
Light nn-sa651s
Panasonic FAQ:
The microwave oven model NNSA651S was manufactured in a way that the oven light turns on only while cooking. - FT
Stupid design!!
Feb 19, 2013 | Panasonic NN-S541 Microwave Oven
Panisonic microwave model NN s952wf Problem; has power (lights. clock and touch pad function), microwave and turn table do not work?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 16, 2010 | Panasonic Microwave Ovens
Panasonic NN-T990SA mfg 2002 Door opens, tray continues to spin-light on-fan on--not cooking.
call the toll free number for the product, service centre might assist, I would not use until fixed
Sep 03, 2009 | Panasonic NN-T990SA Microwave Oven
PANASONIC NN-S952WF FAN AND CAROSEL STILL CONTINUES WHEN DOOR IS OPENED. NOT SURE IF THE MICROWAVE CONTINUING AS WELL WHEN DOOR IS OPEN.
The door interlock system has beem compromised , meaning it shifted out of position or the interlock has broken. Dont continue using it like that it will eventually blow the fuse.
May 13, 2009 | Panasonic NN-S952 Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Microwave Ovens Logo
54 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
