Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Handycam moisture the camera says there is moisture condensation and to turn off for one hour. It has been off for more than an hour. it will not except tapes and just keeps saying turn off for one hour. ??
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: How can I avoid camera
Camera gives Moisture error sign if it really have moisture condensation inside or its moisture sensor itself got defective.
if moisture is inside, blow hot air in camera mechanism for 5-6 minutes by hair dryer (not so closed with mechanism) and check / test.
If problem still exist it means moisture sensor is defective and i know its Sony high-end model camera and know how to fix it yet I would recommend to take camera to Sony Service center for proper repair.
Posted on Dec 06, 2008
caroldon
  • 17130 Answers
SOURCE: Problem with the Sony Handycam
It can be a tiny dew switch mounted on near the drum motor, Which you can change off values with a resisitor for the fault .
Also if you can blow hot air into the cassette tray this would enable the dew switch to open out.
Posted on Sep 28, 2010
How do I fix/clean moisture dew condensation on my sony hdr-pj10 camcorder projector
Try putting it in a container of uncooked rice for 24-48 hours. The rice will draw the moisture out.
Jul 01, 2014 | Sony Handycam HDR-PJ10 Camcorder
Problem with the Sony Handycam DCR-HC32 Mini DV Digital Camcorder Moisture condensation turn off 1 hour
Sep 28, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Flashing drop sign, will not load a tape
Condensation has detected by your camera, leave it on for few hours until moisture dries gone. Hope this helps
Mar 08, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
It says that a moisture condensation has occured on my sony handycam
put it under sun light,for the moisture condensation, that will go,try it.
Mar 08, 2010 | Cameras
HELP ME PLEASE
If moisture condensation has occurred, remove the recordable media (tape) and then turn off and leave the media compartment open for the hour the camcorder is turned off . The camcorder can be used again if the warning indicator does not appear when the power is turned on again.
Moisture condensation normally occurs when the camcorder is brought directly from a cold place to a warm place. It can condense inside the camcorder, on the recording media, or the lens and cause a malfunction.
To prevent moisture condensation when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and seal it tightly. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature.
Oct 25, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Tape stuck in Digital 8 (Moisture Condensation?)
I had same prob with my digital high 8 sony also.
dont panick!!,just get it warm so it gets dry!!
(i only had the prob once in 10 years!)
Dec 18, 2008 | Cameras
How can I avoid camera moisture condensation on my Sony a1e camera, it keeps saying turn off for one hour or eject tape and is doing this constantly.
Dec 06, 2008 | Sony HVR-A1E HDV Digital Camcorder
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
C:32:30 error flashes on screen
It was due to moisture condensation. I left the cassette compartment open and remove the battery for one hour approximately. then fixed the battery again and tried and it worked.
Jul 07, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam CCD-TRV37 Code C:31:10
it is whats called moisture condensation. this happens when the camera goes from a cold to a hot environment very quickly, and vice versa. Simply leave the camera standing with the tape door open for about an hour, and then try again. If this does not fix it, then try cleaning the video heads, and make sure the camera is not in a humid environment, as this will also cause this to happen.
Dec 28, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
64 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
