Question about Motorola Mobility i265 Cellular Phone
I265 texting I can't seem to find the setting to change text from numericle to letters.
When texting hit the menu button ( to the left of the arrow key) it will give u the options there
Posted on Jan 03, 2009
I have a Samsung Convoy. The camera zoom stopped working. The phone is 7 months old and has had no abuse. Also, when I want to text and I'm on the window to enter the phone number of the intended...
menu-messaging-left soft key for settings-entry mode. This will make your text be in letters rather than numbers and then all you need to do is change the letters to numbers in the address of one text and it will continue to be numbers.
Nov 11, 2010 | Samsung Convoy Cell Phone
How do I change to simple text type every letter and not joined
I may be wrong but your talking about predicted text right? Where you type a letter and it comes up with a word instead of the actual individual letter? - you need to change your settings in text, you can simply hold # or * on your keypad (you should see a little icon somewhere saying T9, this means predicted text) after holding one of these buttons for about a second or two, it should disappear, allowing you to type without predicted text on.
Hope this helps,
Jake
Jun 30, 2010 | Computers & Internet
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
I have a simple samsung cell phone from sprint. I want to learn how to text but when I try the letters come out crazy. If I try pressing 3 times to get the f, I get def and this stays like this. How so I...
Simple. Go to your phones settings in the messages ((Messages, Menu, Then It should say Text Input Somewhere)). Change your text input to TAP English((I Believe)). To Text in your current Setting which is called PREDICTIVE TEXT. Simply press the letter you need 1 time and then the next. For Example: DOG
Press the D 1 Time
Then The O 1 Time
Then the G 1 Time
It should spell out by itself, but if not their should be a scroll key((Depends on what phone you have to determine Scroll Key))
Jul 01, 2009 | Samsung Cell Phones
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    Changing to capital letters in texts.
    i might be wrong on this one, but all motorola's are mostly the same on texting. Soto get a capital letter in text just press the 0 before the letter
    Mar 11, 2009 | Motorola Mobility L71 Cellular Phone
    When trying to text incorrect letters appear
    There should be an option somewhere when you are in the message menu on how to switch from the text mode that tries to finish your words for you to the text mode where you have to push the button however many times to get the the single letter you want. Although if you are in the auto finish mode you can simply ignore what it's suggesting and continue spelling out the word yourself if you want. example: hit 9 6 8 one time each to spell the word "you"..buy if your trying to be able to short hand text like "thk u" your gonna have to look around in your text mode settings.
    Jan 02, 2009 | Nokia 6126 Cellular Phone
    Predictive text problems with my samsung u900
    when on predictive text if you want to change a word just click the "0" button (one with the Cross sign) this will cycle though the different words for you
    rate me please thanks
    Oct 04, 2008 | Samsung U900 Soul Cellular Phone
    My predictive text doesn't work properly....
    On mine the key sequence is :
    New message
    New short message
    dash key (middle top button- between "cancel" and "ok")
    Entry setup
    Primary setup: iTAP english
    Jun 14, 2007 | Motorola Mobility RAZR V3
    Motorola Mobility i265 Cellular Phone Logo
    57 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
