Question about Boating
Relay switch for power tilt for Johnson outboard motor 40HP
Bosch 12v 20/30A
  • Anonymous May 11, 2009
    I have a problem with my 1987 150hp Suzuki motor. The trim works intermittently on the 189V stratos. Attempted to use the secondary trim switch at bow to confirm switch operation. When trim working, then both switches work, otherwise nothing works.
    Also, my trim position sensor does not work, but I don't see this being related directly.
    Could a relay somewhere be bad, and where would I trace it.
    Additionally- The middle cylinder that I believe brings the motor entirely out of the water has a leak. Would this affect the trim. If so, then why is performance not always affected.
    Thanks
    Adam.
  • Anonymous Mar 22, 2014
    1995 115 johnson tilt wont go up reverse wiring & relays still only goes down
    Scholar:
  • 157 Answers
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
Posted on Oct 30, 2008
  • Rebecca M Jun 13, 2013
    It is a Johnson 70 hp. 2001
    It looks like a piece of metal inside the throttle may be broken but I don't know enough about it to be sure
85 40hp evinrude stuck in forward?
Evinrude used a shift mechanism located in the lower unit that is actuated by a rod up to the linkage in the motor housing. It could be stuck anywhere along the way or the gear that shifts on the shaft could be immobile due to rust and corrosion.
You may want to find a blowup of your exact model via a Google search. Then starting from the top look for your problem. be sure to mark the position of anything adjustable so you can at least get it back to the original position when you reassemble it.
Find 1985 40hp Johnson Evinrude Outboard Motor Parts by Model Number
Feb 06, 2015 | Light Outboard Motor Boat Bass Fishing...
Why my tilt will not work on 2002 johnson outboard
motor stuck ,relays bad,hydrolic fluid low .
Aug 29, 2014 | Boating
Can't get any power to my evinrude tilt and trim what am I doing wrong ?
Check fuse.try connecting trim wires from t/tilt motor direct to battery supply to see if motor is ok.t/tit solenoid could be faulty,switches could be faulty.broken wire in loom or control box
Aug 16, 2014 | Sierra International 18-6756 Marine Power...
No water flowing out my 40hp envenrude outboard water exaust port
Plossibly clogged intakes (grim in intakes) or thermostats not opening. I would suggest pulling the lower unit and then your thermostat housing and use a water hose to back-flush it out. Also check the thermostats in boiling water to make certain opening.
May 09, 2014 | Clymer Evinrude/johnson 2-40 Hp Outboards...
My 1973 Johnson 40hp boat motor will not shift in forward, Only reverse
Try searching our boating forum for answers to your Johnson motor problems. Johnson Evinrude Outboards
Apr 02, 2014 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
The trim/tilt on my 97 Johnson 150 outboard is not moving. Tilt motor runs. Some time ago my mechanic told me not to run the tilt all the way to the top, which is, I think, what happened. Any ideas on...
Make sure there is not a spring loaded locking lift latch engauged. If there is you will see a little movement and then the motor will sound slower. If there is no movement and the motor runs the same speed with no change you are low on hydraulic tilt and trim fluid.
Please take a moment and rate my answer............ Thanks
Nov 28, 2010 | Sierra International 18-6756 Marine Power...
Evinrude 225hp will not power tilt batteries OK manual release will turn but still not able to tilt motor?
Check trim tilt switch (if that's ok ) Try the trim / tilt relay inside the engine cover.
Could also be limit switch above the trim motor up further under the motor.
My bet is switch or relay
Good luck
Aug 14, 2010 | Clymer EvinrudeJohnson Outboard Shop...
Boating Logo
1,183 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
