-   It's been working great. All of a sudden, over the weekend, I had the same problem.
When I pull the trigger, a rod moves and it does press down on a round white membrane, but I can't see happens after that - This machine really helps to keep the dander down in the house, and I'd love to repair it myself!
-   pamyo
Feb 02, 2009
-   This is my second Hoover floor mate with the same problem. The trigger will not delivery the water for cleaning. I read the solution, but I don't know how to add an extention to the plastic piece that bends. Can anyone be more specific and is this a DYI project? I wouldn't know where to start to "add an extension"...-   sgruenig
Jan 31, 2009
-   Will not release cleaning solution and h2o. I took it apart and also pulled trigger which is working properly. I also pressed the rubber opening where the cleaner is suppose to be released, and it is working properly as well. There has to be some sort or malfunction between the trigger rod pressing down on the rubber opening to the cleaning solution vessel.-   corbinsmommy
Jan 17, 2009
-   DO you know where you can get that plastic rod that connects to the trigger? Ours is broken, can't find it on Hoover or other parts sites I have looked on.
-   Guest
Dec 10, 2008
-   Sometimes it puts out enough solution and then other times way to little. It seems to depend on the angle of the handle. Is there any adjustment to the flow. I will check on the plastic rod to see if it is bent.
-   ad-hoc
The trigger is connected via a piece of plastic that tends to bend over time. I brought it into the shop and they added an extension to it and it worked again. Can a metal rod replace the plastic? I don't know, since I hadn't pulled the unit apart. Like you, I had no idea what the problem was so I brought it in. If you are handy, this may help you save the cost of the repair. Incidentally, I was told that this is a VERY common problem.
After reading postings I created my own solution. I took a 1.5cm (approximate length) flush head finishing screw and screwed it into the button contact of the white memebrane and adjusted it to the necessary heigth to make the rod depress at the corrrect depth. My initial placement was too high and I had a continuos flow of water, but was able to fine tune. Also note the head of the screw I used was a similar circumference of the nob of the white membrane.
Was this helpful?
Yes
No
Popular Solutions for Hoover Floormate H3000 Upright
Floormate Wet/Dry Water pours from the clean water reservoir when the machine is tipped back in the...
(More)
Floormate Wet/Dry Water pours from the clean water reservoir when the machine is tipped back in the cleaning position. The reservoir is definitely in its proper place.
