Question about Haier 65-Pint Dehumidifier
Error code E1 on Haier HD656E dehumidifier
3 month old unit - error code E1 - will not operate -motor will not run. Filter is clean. Tried unplugging and replugging without any change. What does E1 message signify and can I fix or should I call company for warranty work? Thanks.
  • Anonymous May 08, 2009
    same here, any help?
IrishDruid
  • 2712 Answers
SOURCE: Haier Dehumidifier stuck on 45
Check the coils at the back of the dehumidifier to see if there is any frost buildup on it. If there is, turn off the machine for a while until the room warms up and melts off the frost. The machine works by condensing the moisture in the air over these coils, so if the coils are frosted over, or are not cold enough, the moisture cannot condense. If the coils are not cold enough, you may want to get it refilled with refrigerant. You will need to take it in for servicing in this case.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 29, 2008
IrishDruid
  • 2712 Answers
SOURCE: HAIER HD656E
It looks like there is a short somewhere in the machine's circuitry. You will need to get this serviced by a qualified technician.
heatman101
  • 43501 Answers
SOURCE: haier hd656e, my dehumidifier runs about 30 sec and turns off,
This sounds like a main circuit board problem and is very common with many dehumidifiers... They can be replaced on some units. You can do a search online for the part easily...to see if it is available.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
evanusa
  • 197 Answers
SOURCE: I need an owner's manual
Here is a link for you to download the manual. http://www.retrevo.com/support/Haier-HD656E-manual/id/951dj390/t/2/
Please rate this post! Thank you!
Posted on Jun 10, 2011
  • 4736 Answers
SOURCE: I need a manual for
Here is a link to what should be the Owner's Manual for your unit. If it's not identical, it should be close enough to it, to help you.
http://www.haieramerica.com/en/asset/product/31b6415af4
Hope this helped you. Please let me know. Thanks.
E-1 error
The E1 error code indicates that the air intake filter needs to be removed and cleaned. Be sure to turn the unit OFF & unplug it before removing the filter. Never operate the unit without the filter in place. Doing so, could damage the unit.
Hope this helped you and thanks for choosing FixYa.
Sep 09, 2011 | Danby DDR4588EE Dehumidifier
Unir ran good for 8 months then cut off with current humidity reading LO. Humidity is not LO. Have to set below 40% then runs all the time. The AUTO humidistat sensor must be broke. 1 year...
In addition to a faulty humidistat sensor, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, contact Haier Customer Support
1-877-337-3639, before your warranty expires.Haier units will generally show an E1 code if a sensor or circuit is faulty and unit will not run at all.
I hope this helped you troubleshoot & solve the problem
Aug 11, 2011 | Haier DE65EJ Dehumidifier
Our Haier runs but does not remove any water from the air
Paula, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 02, 2011 | Haier HD656E Dehumidifier
What does e1 mean
For many window air conditioners this code is simply a reminder to clean the air filter. After like 750 hours of run time this code pops up and you have to clean the filter and then reset the unit before it will work again. To reset the code you need to simply unplug the unit and then plug it back in again.
Hope this helps; good luck.
Jun 13, 2011 | Haier 45-Pint Dehumidifier
Water is not going into the tank, but it does run and panel lights up. Filter is clean. It worked for the past 2 months.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running.
If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils.
If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck
Aug 16, 2010 | Haier HD656E Dehumidifier
I have an Haier HD656E dehumidifier. The past couple of days it has been on, but only the fan is running. I hear the noise as if the evaporation part wants to turn on, but is not. I have the temp. set...
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 15, 2010 | Haier HD656E Dehumidifier
Haier hd656e, my dehumidifier runs about 30 sec and turns off,
heatman101
May 16, 2010 | Haier HD656E Dehumidifier
Blower motor quit
u should have a number on the unit to call if not call the place it was purchased and see if they can get u in touch with someone who can help but that should definitely be a warranty part
Feb 23, 2010 | Haier HD656E Dehumidifier
Humidifier collects very little water
Check to see that the air is flowing freely through the dehumidifier. They will accumulate dust particles and become plugged. Also make sure that it is not freezing up (you would see ice forming inside through the vent openings). I have had to remove the case to clean lint from some units to get them to operate more efficently. Always unplug the unit to clean and service it.
Jul 03, 2009 | Haier HD656E Dehumidifier
Haier 65-Pint Dehumidifier Logo
432 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
