Understanding RAM specs
Hi eletech, I was hoping you could help me out with this one:
What's the diff between say, 4gb of 667 or 800Mhz ram and 2gb of 1066 or 1200? Is less Ram at high speed a better option? I guess it goes without saying that 4gb at 1200Mhz would be ideal, but I dont think I can afford that.
Mobo is ASUS p5q se/r
  • findads Oct 30, 2008
    the processor is 3.16 core 2 duo, mobo is asus p5q se/r (capable of handling 16gb ram!??) At this stage Im prob going to go with kingston ddr2 2gb sticks *2. but then, why would they make a 16g board?
  • jason May 11, 2010
    no , because your processor is the one doing the transfer speed
    if you want 4g with a faster rate then two 2g ram chips with the 1200mhz transfer would be faster
    but if you have a 4g at 800mhz it will be faster, because of the time it takes the two 2g chips to transfer will be more time since theres two of them transfering instead of only one doing the job
    the way they work is the amount of info transfered at one time, that determines how much better they are. the more info that can be transfered at once the better, but how fast that info is transfered depends on the processor
    does that help you understand a little more?
    electech
  • 4,234 Answers
Sorry to disagree with you Electech1, but you don't quite understand how memory works. Let me explain:
The memory transfer speed is determined by the memory bus speed. This is determined by the motherboard in question. The specs for this should be listed with the motherboard specs. Installing memory sticks that are capable of a higher speed WILL NOT make the memory access faster. As an example, the old PC100 and PC133 memory sticks worked with 100 and 133MHZ bus speeds respectively. Installing PC133 sticks into a machine designed for PC100 would work fine, but at teh same speed as PC100. Installing PC100 memory sticks into a bus designed for PC133 could work but would not be guaranteed and could fail in odd ways. This was because the PC100 memory was not tested to work at the higher bus speed. The bottom line is that the memory installed MUST be matched to the bus speed.
Depending upon the design of the process and memory system, it is possible to have parallel memory accesses. The physical number of memory sticks will not have any significant impact on this.
In terms of the processors:
Dual core means that both processors can be active performing a single program in parallel. This means that a process that requires 100 cycles of processor time can be completed in less than 100 cycles of true time because of parallelism. This happens at the instruction level and is handled by software language compilers that generate the end instruction stream in such a fashion as to provide parallel operations. I could go on for days on how this works, but realize that in effect this type of design allows for parallel operations which will cut down the actual time required to complete functions.
The amount of parallel operation will depend upon the type of program being run. The more calculation intensive the application, the more likely benefit of parallel operations.
Dan
Posted on Oct 31, 2008
  • ABRsvcs Nov 03, 2008
    Not to be argumentative here, but Electech1, you do not understand how the dual and quad cores work. Compiler technology has advanced to the point where even signel threaded applications can take advantage of multi-core processors. No matter what language you use, the computer only understands 1s and 0s. Even more than that, it can only add and shift. Without getting into a long drawn out discussion about computer architecture (I have taught courses on this for college), there will be a benefit to multiple instructions being executed in parallel even with standard non-computational programs. The root of the Digital Equipment Alpha processor used this technology (which was later incorporated into the Intel chipset), to increase the efficiency of overall processing by scheduling instructions for the CPU to execute so there were few to no wasted cycles. Some instructions take multiple clock cycles to complete. If a parallel processor can execute instructions while another completes its own, there is parallelism and improved performance. The dual and quad core CPUs incorporate this as do the compilers that generate the code streams. Therefore, it is likely that a duial or quad core system will exceed the performance of an even faster clocked single CPU.
    Dan
Each type of duo is different, but mostly it disables one to conserve power untill the extra processing is needed
click the link and read! http://en.wikipedia.org/wiki/Intel_Core
Posted on Nov 01, 2008
  • 905 Answers
They expect to devlope a 8g ram, and that would boost memory transfer to the highest possible for that board, but also a new developement for a new board they are working on, which would allow the ram to be used in the boards they are developing
electech
  • 2 more comments
  • jason Oct 31, 2008
    also on the core duo works like this : when one processor is at its full speed then the other one starts to proccess untill it reaches its highest speed, if needed , each processor is rated at 1.58g
    electech
  • jason Nov 01, 2008
    Multi-cores provide multi-threading wherein it subdivides the tasks on its cores. Thus A 2.4 GHz processor can subdivide tasks into it's 4x 2.4 ghz cores. Intel's multicore architecture is different from AMD's. Intel's Core2 quadcores is like having 4 employees that can do different tasks, AMD's Phenom quadcore is like having 4 employees that can do the same tasks thus whenever there is an overloading of tasks on a core, another core can help.
    Aside from that, the *software* needs to be able to utilize a dual core processor for it to take advantage of running tasks simultaneously. If the music software you are using is not **multi-threaded** it will only utilize ONE core. In this case a single core fast processor is better than a dual core, because only "half" of the dual core's total processing power will be used, whereas 100% of the single core processor will be used.
    In the most basic terms, if your playing a game that needs a fast CPU, stay with the fastest single core you can get, x32 VS x64 is a totally different argument.
    If your someone that does a lot of multi-tasking work, or an maybe using an application that does a lot of things at once, like photoshop, you will see a good benefit to using dualcore. Maybe you just like to run teamspeak while listening to music on itunes while posting on your blog and killing aliens on halo, that would be a case for dualcore. If you run only the game, or only crunch numbers, or only browse the web, single minded tasking, that's single core world.
    Update [Sept. 2007]: At this point, pretty much any motherboard you buy is going to have either Dual Channel DDR, DDR2, or DDR3. Most but not all Dual Channel supporting motherboards will operate in a slower single channel mode if using one stick of ram, but work best with ram in pairs. On these boards its best not to try the odd 3 stick of ram configuration though as some motherboards will have problems operating in this fasion or plain won't POST.
    It's worth noting that at this point, RAMBUS is no longer widely available nor is it supported by any curent motherboard chipset. Those with Rambus based systems are strongly encouraged to upgrade to systems utilizing DDR2 or DDR3. As far as which to go with, [DDR2 vs DDR3] right now DDR2 is much much more common than DDR3 and cheaper. DDR3 will probably start becoming common sometime in 2008 when more motherboard chipsets come out with full support for it.
    it is important that you understand how to figure out the processor multiplier and the proper system clock. When you go to purchase a processor you are told in the ad / description for the processor what FSB it has. To determine the proper system clock for the processor simply divide the FSB by the performance enhancer (2 for the double pumped bus on AMD Athlon XP/Thunderbird/Duron processors or 4 for the quad pumped bus on the Intel Pentium 4).
    If your processor has a ... FSB then the system clock speed should be:
    66MHz (Various Celeron and older): 66MHz clock
    100MHz (Pentium II / Pentium III / K6): 100MHz clock
    133MHz (Pentium II / Pentium III / K6): 133MHz clock
    200MHz (Athlon, Duron, Thunderbird): 100MHz clock
    266MHz (Thunderbird, XP): 133MHz clock
    333MHz (XP): 166MHz clock
    400MHz (Pentium 4): 100MHz clock
    400MHz (AMD XP): 200MHz clock
    533MHz (Pentium 4): 133MHz clock
    800MHz (Pentium 4): 200MHz clock
    800MHz (AMD64): 200MHz clock
    1066MHz (Pentium 4/LGA775): 266MHz clock
    1333MHz (Pentium 4/LGA775): 333MHz clock
What is the maximum memory on a Gateway MX8734 laptop?
Hi Anon
the Gateway MX8734 motherboard has two memory slots each capable of handling a maximum of 2gb of ram.
So, 2gb is the largest single ram module, and 4gb is the largest total amount of ram.
If you are uncertain if your motherboard is capable of handling a 4gb ram upgrade then check with the memory suppliers first.
In practice I have always found that the performance difference between 2gb and 4gb of ram is slight.
Aug 14, 2014 | Gateway Computers & Internet
Can my mercury motherboard PI945GCM.V1.0 support 4(2+2) gb ddr2 ram
This motherboard will support only Maximum 2GB DDR2 RAMS.
Thanks for using FixYa.
Jun 06, 2011 | Mercury P4VM800M7 Motherboard
I have a p4m900mother board. i had 1gb ram in each slot. running 2gb ram. i replaced the one with a 2gb hoping to run 3gb ram but my pc will not boot. i have switched slots and still nothing. i can run up...
Make sure you have installed the correct type of ram into the board. Here are the ram specs for that board
• Memory:
Support DDR2 533/667 MHz
2 x DDR2 DIMM Memory Slot
Max. Supports up to 4GB Memory
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Biostar P4M900-M4 Motherboard
No audio after installing 2*2GB
Your motherboard supports maximum 2GB RAM. So, the problem is due to the 4GB RAM.
Check your motherboard details here:
http://www.msi.com/index.php?func=prodmbspec&maincat_no=1&cat2_no=&cat3_no=&prod_no=260
Hope this solves the problem. Thanks.
Jul 22, 2009 | MSI K9VGM-V Motherboard
Purchasing RAM
DDR3 modules can transfer data at the effective clock rate of 800–1600 MHz using both rising and falling edges of a 400–800 MHz I/O clock. In comparison, DDR2's current range of effective data transfer rate is 400–800 MHz using a 200–400 MHz I/O clock, and DDR's range is 200–400 MHz based on a 100–200 MHz I/O clock.
decide urself, depends onur system support and ofcourse ur buying capacity.
DDR3 is better
Oct 30, 2008 | Computers & Internet
Understanding RAM characteristics
Regardless of the speed RAM is nothing more then a container for running programs. Hence the more ram you have the more programs you can run concurrently (at the same time)
Speed has to do with how fast the running programs can be put into and accessed within the RAM.
Hope this helps
Buying RAM
Ok first off, you're right. 4GB at 1200MHz would be ideal, but there's only one problem. Alot of computers don't have a 1.2GHz front side bus.. so even though the ram can run at that speed if you're frontside or backside bus can't keep up it's pointless. Fist figure out how fast your FSB (front side bus) is and buy your ram accordingly. Ideally, 1GB at 1.2GHz will out perform 2GB's of 667MHz. But there are other variables to consider, but i'll spare you the essay.
Also keep in mind, if you're replacing ALL the old ram in your system then you'll see a nice performance gain, but if you're only adding to your existing ram, the new ram stick(s) will only run as fast as your old ram.. so if you have a stick of 1GB at 667MHz, but buy two new 2 GB's at 800MHz, the new sticks will only run at 667MHz, because ALL your ram must run in sync.
Hope i answered your question!
Ciza
RAM comparison for asus p5q se/r mobo
Appreciate the direct "Ask Me".
Interesting choice which would seem to boil down to quantity over quality. Personally, I would rather go for quality, that is the highest motherboard acceptable/allowable speed of the memory. Even if the memory is only 2Gb and you can run it at max speed (with latency 2) it should dramatically improve performance. Additionally, the 2Gb (low compared to 4) could be compensated with an efficient memory management of the OS (hopefully XP and not Vista). Memory usage/management could be tweaked at the registry, msconfig, Startup and general ways of how the PC is used.
It would be appreciated for a postback/update if and when you have installed your choice of memory and hopefully, I can be of further assistance with a few tips on Memory usage/management; tweaking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
I own a Toshiba Satellite M110...The problem I'm having is I can't get the laptop to run on anything higher than 2gb of ram...Yet the booklet and numerous tech and information sites say that it can run...
if i will suggest i think u can try a diff ram most times rams that r not compatible with each other may not run on a system. so to veriyfy that yr new 2gb ram pair is working try to install them one after the other that is, insert the first 2gb ram boot yr system if ok, shut down remove it n insert the other 2gb if it ok then they should work since it has been tested by the manufacturers n is written in the manual..
NB most times especially china products they may write anything on the body of yr machine but u will see a diff thing working so i dont know
guess u find help
May 27, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
1,443 people viewed this question
David Payne
David Payne
