Question about Whirlpool RCC3024 Electric Cooktop
No heat. could fuse be blown
How to check it. breakers are okay...
Well ****.. i guess have to get repairman... tough to afford right now with husbands medical bills..
thank you for help!!! i appreciate your input
Posted on Oct 30, 2008
    President:
  • 1,314 Answers
IT WOULD HAVE TO BE A POWER PROMBLEM FROM YOUR HOUSE sorry about caps lock on start at house breakers and and check wiring
  • robert samples Oct 30, 2008
    no fuses in cook top each eye on its own circet
    has to be incomming power or neautrl prob
2 Suggested Answers
SOURCE: can fuse be blown?
yep... physically reset breaker... :-)
Won't heat all settings
Locked cook-top? Check breaker, fuses, plug
Jan 03, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
I was roasting a chicken in my Maytag Cooktop when I heard a loud buzzing and a "pop", all of the power in my house went out. Something had tripped the breaker. My husband reset the breaker but my stove...
there is a short for sure, sometimes when the heating element burns out and melts, it touches the metal inside the housing causing a short. inspect the heating elements in the oven(top and bottom). the loud buzzing sound is what a shorting out heating element makes as it melts like a weldin rod, usually because of using tin foil(not recommended)
Jun 15, 2009 | Maytag MEC5430BDS Electric Cooktop
The cooktop does not come on
It sounds like the circuit breaker is kicked or the fuse is blown.
look in your electrical panel for the breaker and in the fuse box to see if the fuse is blown.
Feb 12, 2009 | GE 30 in. JP340 Electric Cooktop
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
Solid element cooking top slow in heating up
It sounds like you have lost 1 leg of 220V power to the unit. Chances are, one of the elements shorted to ground, then blew itself open.
Find the breaker or fuse box, and reset/replace breakers/fuse. If it blows again, you'll have to locate which element is bad, or where the short is.
I can help more once I know if there was a breaker trip, or fuse was blown. I will also need to know if it is one element, or all the elements., that exhibit the same problem. I can instruct you on identifying the bad element as well, and replacement elements are available.
Jan 14, 2009 | Jenn-Air Cooktops
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Can fuse be blown?
youl have to pukk out the unit and check the connection/installaiton. youll need to determine if you have proper voltage going to machine. ther if no fuse on the machine, more than like a power supply issue
Oct 30, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
GE electric cooktop
Try looking at the junction box that it is connected to. Maybe one or more of the wires have burned off or come loose from the wire nuts. How many amps is the breaker? Most electric codes require separate circuits (Breakers) for each appliance. First turn off the breaker. There should be an outlet box of some kind on the wall or behind the cabinet. Follow the wire from the cooktop and see where it goes. Open it up and check if any wires are burnt or loose. If it was installed wrong I would change it. Most cooktops shouldn't be fused at more than 30 amps. Single ovens the same, double ovens up to 45 amps. The problem is if they used an old range outlet with 6 gauge wire and tried to connect both appliances to the same wire. This is hard to do without it coming loose.
Jun 10, 2008 | GE 30 in. JP326 Electric Cooktop
Jenn-Air Electric stovetop / oven range SCE4340B - Fuse blown ? ? ?
Andy, sounds like you lost a leg of power. Check the breaker box first. Maybe the contractors tapped an existing breaker instead of adding one for the burner/broiler. You would have to check the terminal block on the range. Should read 120V from each end to center and 220V across the two outer terminals. If you don't have this, something got messed up with the contractors. Catriver..post back
Mar 04, 2007 | Jenn-Air JED8430 Electric Cooktop
Whirlpool RCC3024 Electric Cooktop Logo
171 people viewed this question
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
