FixYa.com
Tags:
Acer TravelMate 4000 PC Notebook
Not working (by 9 users)
posted by likethis on Sep 09, 2006
I am not sure what the problem is, but its when i turn the laptop on it doesnt work.
the only thing that works is the power light it goes on and then thats it, the light stays on, but the monitor and laptop do not do anything. the monitor stays plain black and thats it. i tried taking out the battery, and putting it back in, but it didnt do anything.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Comment by jbgrem, posted on Aug 17, 2008
Turn on the computer, lights are on but the screen stays black.
Have taken out the battery, etc.
Please advise.
Comment by telycom, posted on May 29, 2008
Comment by Guest, posted on Apr 02, 2008
powers on, blue light stays on, fan is on, but screen is blank
Comment by JamieB, posted on Feb 14, 2008
yes...mine is doing exactly the same thing (actually it's not mine - i'm borrowing it from a friend!)
The laptop turns on fine (power light, battery charge light and fan are on) but nothing on the screen.
I've tried discharging and recharging the battery, removing everything including hard drive, dvd drive, battery and additional memory but it's just been the same.
Help!
Comment by occupier, posted on Dec 06, 2007
when i turn on it does nothing i put the charger in and the red battery light comes on for about 15 seconds then goes off dont hear anything from the laptop?
Best Solution
posted on Sep 09, 2006
Helpful (85)
xamarshahx
Rank:Apprentice Apprentice
Rating: 77%, 36 votes
It could be a variety of things, did you hear the other parts spinning and whirring as before? Then it could be just the screen or video card. Try hooking it up to a regular monitor and see if it will display there. Other problems could be HD failure, but usually your computer would freeze on startup or your BIOS will tell you that instead of a blank screen. Have you tried contacting the manufacturer for tech support on the issue? It is hard to diagnose blank screens over the net due to the lack of information you can get (ie. error messgaes, etc.....)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 08, 2008
Not Rated (0)
JulianDarius
Rating: 0%, 0 votes
If you're getting ANYTHING readable on the screen, the problem is likely not the screen. Dim screens are one thing, and messed-up screens are likely problems with the physical screen. If nothing's showing, it's likely the connection running through the hinge into the screen, which can be a little tricky on laptops, though the whole connection between motherboard and screen is suspect. This is a problem because the problem isn't always immediately visible even upon opening the laptop. You might do so, if you know what you're doing, in order to examine and reconnect everything. But you're likely going to have to pay to have the wiring repaired (and maybe even the screen itself, though that's far less likely).
Solution #3
posted on Jul 30, 2007
Not Rated (0)
mohmo
Rating: 0%, 0 votes
my problem about all display. no start and can use keyboard too. and when i try to look in folder there is change everytime.. Please HELP...
Solution #4
posted on May 28, 2007
Not Rated (0)
BenjaminaBOY
Rank:Master Master
Rating: 68%, 15 votes
The monitor might be off, because it's possible on most Laptops that you can turn the monitor on and off.
Comment by BenjaminaBOY, posted on May 29, 2007
And sometimes you will hear nothing, then you will hear a Loud motor sound.
Solution #5
posted on Oct 11, 2006
Not Rated (0)
Kegtapper
Rank:Guru Guru
Rating: 86%, 84 votes
kegta... indicated that his solution for
Inspiron 1150 PC... Problem
is valid for all Acer PC Laptops
Check to see if the DC POWER Jack is loose. HOLD the bottom of the jack slightly tilted upward (do not use a lot of force). While holding PRESS the on button.
If it comes on and stays on, you problem is the notorius power jack cold solder issue. The jack will have to be repaired. Either by DELL or a qualified expert that has done a number of these.
It is not a easy task by any means. A skilled ELECTRONICS TECHNICAN could do it. But not a Computer Technician, because they generally just replace parts and do not do component level repairs
Solution #6
posted on Oct 06, 2006
Not Rated (0)
ianniow
Rating: 0%, 0 votes
I am afraid it is not a solution only to repeat the problem I have exaclty the same. It appears to switch on but then nothing not even mumlock light or caps lock light comes on or off
Solution #7
posted on Sep 13, 2006
Not Rated (0)
Antony
Rating: 0%, 0 votes
I had the same problem with my C640. What I did was take out the memory chips powered up. Then turn it off and reinstalled the chip, and poof. Every was working. I hope this will save your problem to.
This Problem Also Relates To: HP HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook HP HP Compaq 6720s Notebook PC PC Notebook HP PAVILLION N5415 NOTEBOOK, 900 MHZ, 256MB, 10 GIG, 8X DVD, Win XP (HPN5415) PC Notebook HP Compaq nx6125 PC Notebook HP Compaq Evo n610c PC Notebook Panasonic (CF18DJAMXKM) PC Notebook Sony VAIO PCG-K35 PC Notebook
Can you Help with these PC Laptops problems?
PC Laptops
please help me agian
please help me about my... Answer This...
PC Laptops
problem vith lap-top
Several things you need to... Answer This...
PC Laptops
sony PCG-4g1m
I m having problem to USE lan... Answer This...
PC Laptops
camera assistant software
I can't find camera assistant... Answer This...
PC Laptops
microphone problem
hi my name is anil my laptop is... Answer This...
8 Other Users Have The Same Problem - Continued
Comment by dlln-blnd, posted on Nov 25, 2007
Comment by lordk1, posted on Nov 20, 2007
Am an engineer(laptop board problem fixing),the system(acer laptop computer) i have with me powers on but the processor doesnot process(dose not get hot even when i have tried a working processor on the board and have changed the memory as well).So the system wont just display nor the caplock functions.where could likely be the fault on the board and how do i solve this problem?
Comment by jacobpampady, posted on Nov 15, 2007
Yes, I am facing the same problem with My Acer 5002 WLMi.
When powered on, only the power ON LED comes on, the sreen is completely blank (black).
I can hear some sound, look like it is from HDD.
Before the screen became blank, I got a vertical white band in the middle of the screen for 30 seconnds. I recall few weeks back, the acreen had some funny characters blinking in black and white.That problem went away when I re-booted.
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
