Understanding RAM characteristics
Hey Ginko, I was hoping you could help me out with this one:
What's the diff between say, 4gb of 667 or 800Mhz ram and 2gb of 1066 or 1200? Is less Ram at high speed a better option? I guess it goes without saying that 4gb at 1200Mhz would be ideal, but I dont think I can afford that.
Mobo is ASUS p5q se/r
  • 104 Answers
Regardless of the speed RAM is nothing more then a container for running programs. Hence the more ram you have the more programs you can run concurrently (at the same time)
Speed has to do with how fast the running programs can be put into and accessed within the RAM.
Hope this helps
Posted on Nov 11, 2008
Can I add more then 4gb
Peter, google search your make and model #, specs and it will come up telling you how much and what ram to use. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RAM For Gamers What Do The Specs Mean And How Do They Alter Performance
How to Check Computer Specifications
Understanding Identifying and Upgrading the RAM in your PC
Jul 28, 2016 | Computers & Internet
Hi my pc lost 4gb of ram out of 8gb.. amd quad 2x4-630 //msi 785gm-p45 model7623
Hi jcarter123,
It's okay Sir.
The 4GB of your RAM weren't lost.
The PC reads the whole 8GB of your memory but it can only display 4GB.
Hope this helps you a lot.
Thank you for using FixYa!
Nov 01, 2011 | MSI Computers & Internet
I have a M2A-MVP motherboard and I am trying to use more than 4GB of ram on Windows 7 64Bit but when I install more than 4GB of ram I get a blue screen at start up then it resets but in safe mode it shows...
how many ram modules are you trying to use and what sizes always keep the largest ram closest to the cpu central processing unit and it might be a compatability problem always try to keep using the same type of ram
hope this helps
Jun 20, 2011 | ASUS M2A-MVP - Motherboard - ATX - 480X...
I have a p4m900mother board. i had 1gb ram in each slot. running 2gb ram. i replaced the one with a 2gb hoping to run 3gb ram but my pc will not boot. i have switched slots and still nothing. i can run up...
Make sure you have installed the correct type of ram into the board. Here are the ram specs for that board
• Memory:
Support DDR2 533/667 MHz
2 x DDR2 DIMM Memory Slot
Max. Supports up to 4GB Memory
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Biostar P4M900-M4 Motherboard
Purchasing RAM
DDR3 modules can transfer data at the effective clock rate of 800–1600 MHz using both rising and falling edges of a 400–800 MHz I/O clock. In comparison, DDR2's current range of effective data transfer rate is 400–800 MHz using a 200–400 MHz I/O clock, and DDR's range is 200–400 MHz based on a 100–200 MHz I/O clock.
decide urself, depends onur system support and ofcourse ur buying capacity.
DDR3 is better
Oct 30, 2008 | Computers & Internet
Buying RAM
Ok first off, you're right. 4GB at 1200MHz would be ideal, but there's only one problem. Alot of computers don't have a 1.2GHz front side bus.. so even though the ram can run at that speed if you're frontside or backside bus can't keep up it's pointless. Fist figure out how fast your FSB (front side bus) is and buy your ram accordingly. Ideally, 1GB at 1.2GHz will out perform 2GB's of 667MHz. But there are other variables to consider, but i'll spare you the essay.
Also keep in mind, if you're replacing ALL the old ram in your system then you'll see a nice performance gain, but if you're only adding to your existing ram, the new ram stick(s) will only run as fast as your old ram.. so if you have a stick of 1GB at 667MHz, but buy two new 2 GB's at 800MHz, the new sticks will only run at 667MHz, because ALL your ram must run in sync.
Hope i answered your question!
RAM comparison for asus p5q se/r mobo
Appreciate the direct "Ask Me".
Interesting choice which would seem to boil down to quantity over quality. Personally, I would rather go for quality, that is the highest motherboard acceptable/allowable speed of the memory. Even if the memory is only 2Gb and you can run it at max speed (with latency 2) it should dramatically improve performance. Additionally, the 2Gb (low compared to 4) could be compensated with an efficient memory management of the OS (hopefully XP and not Vista). Memory usage/management could be tweaked at the registry, msconfig, Startup and general ways of how the PC is used.
It would be appreciated for a postback/update if and when you have installed your choice of memory and hopefully, I can be of further assistance with a few tips on Memory usage/management; tweaking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
4gb ram not detected
First of all kindly specify what how many rams slots and how many ram chips are there
like 1 X 4GB or 2 X 2 GB
with RAM there can be a few problems
1) the frequency of ram whichmotherboard supports might be less than the freq at which the ramyou are puttin works, hence in this case RAM wont work on this motherboard and ull have to get the RAM replaced
2) some motherboards donot support a 1 x 4 GB RAM where as they might support a 2 X 2 RAM (ifyou do have 2 mem slots for ram)
and then there is the mosttrivial problem of the slot not being clean or arm not being putproperly, i can think of ne other reason for the ram not workingproperly..
For further assistance feel free to mail me at
Aug 27, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
I own a Toshiba Satellite M110...The problem I'm having is I can't get the laptop to run on anything higher than 2gb of ram...Yet the booklet and numerous tech and information sites say that it can run...
if i will suggest i think u can try a diff ram most times rams that r not compatible with each other may not run on a system. so to veriyfy that yr new 2gb ram pair is working try to install them one after the other that is, insert the first 2gb ram boot yr system if ok, shut down remove it n insert the other 2gb if it ok then they should work since it has been tested by the manufacturers n is written in the manual..
NB most times especially china products they may write anything on the body of yr machine but u will see a diff thing working so i dont know
guess u find help
May 27, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
981 people viewed this question
David Payne
David Payne
