Question about Kenmore 74602 Gas Dryer
Dryer won't heat
I have a Kenmore gas dryer, It turns but does not heat. I have checked the ignitor and sensor and both have continuity. Can you help?
Thank you,
Don
    Scholar:
  • 121 Answers
Hi! donj56
There are a lot of challenges in checking the electrical system. If this dryer has a traditional timer it is best to find the circuit diagram included inside the dryer. Consult the diagram and make sure you have the same voltage on the input of the timer and then on the circuit feed to the igniter. The case is a good ground so you do not need to connect to the Neutral. Let me know the dryer model number? Is the dryer in a high humidity environment? Also, how old is the dryer?
Posted on Oct 30, 2008
Number 59 is the fuse. if it is blown due to air restriction or vent blockage the dryer will run but no power will be transferred to the gas assembly. If you are indeed getting power to the gas assembly you want to first check the flame sensor for continuity. If it is open the ignitor won't glow. If the sensor is good check the ignitor itself is what I would do next. The following videos show how a gas dryer works and How to get into the type dryer you ahave which is a 4 wheel drive type,
4 wheel drive electric dryer like yours:
Gas dryer how it works:
Oct 28, 2012 | Kenmore Dryers
Dryer won't heat I've replaced the heater element
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Kenmore Dryers
My Kenmore gas dryer 110.97566210 works and heats when starting cold, after several cycles, the ignitor glows but the gas valve won't re-open. Is there a high limit sensor? i read a faulty ignitor can...
heatman101=-=-
Aug 05, 2011 | Dryers
My Kenmore 500 Series electric dryer runs, but no heat. Elements never get warm. All thermal sensors show continuity. When I checked for resistance through the elements, I got infinite ohms. Perhaps I'm...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore propane clothes dryer not heating
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Kenmore electric dryer not heating
heatman101
Jun 20, 2010 | Kenmore 63942 Dryer
Kenmore Dryer 65512 won't heat
heatman101
May 14, 2010 | Kenmore 64742 Electric Dryer
Dryer heats up then pilot lght turns off, dryer
heatman101
Oct 20, 2009 | Kenmore 63942 Dryer
Dryer barrel turns no heat this is a gas dryer 90 series kenmore
remove front cover, this will allow you to remove top cover, then take off drum belt and you will see the gas valve,follow the gas tube to the fire funnel and you will see the ignitor, check for continuity, if its good, then it could be a flame sensor or the control board at fault
Sep 24, 2009 | Kenmore 75944 Gas Dryer
Dryer gas
heatman101
May 25, 2008 | Kenmore 74112 Gas Dryer
Kenmore 74602 Gas Dryer Logo
79 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
