Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Hot water hook up leaking
Leaking at hot water hook up from machine replaced hose still leaking
  • 94 Answers
Hi bigger
turn off the valves disconnect the hose check the threads on the water intake valve(bit the hose screws onto) are not damaged by cross threading. then try wrapping silk plumbing thread tape(available at all plumbong outlets including B&Q,Homebase etc.) around the threads(wind it clockwise and give it plenty)then check the rubber washer at the end of the hose is not damaged of missing and reconnect the hose
Posted on Oct 30, 2008
When my Kenmore machine is running on the wash cycle warm/warm no water is coming at all. I could run the machine only with cold water even on the cycle warm/cold.
Most likely the hot water hose is plugged up, or least likely, the hot/cold valve is broken or plugged up.
Find a large container, or better yet, hook up a garden hose that you might try the faucet where the hot water is hooked up and see if water will come out of it when the washer hose is not hooked up there.
If it will not, you have a plugged up hot water pipe or the water heater shut off valve is closed.
If you get good water pressure and hot water from the faucet, look at the filter screens that are inside the ends of the hot water hose and see if any are plugged up.
There may be several.
If not, perhaps the inlet water solenoid has failed. That plastic part is where the hoses attach to the washer itself.
God bless your efforts.
Jan 22, 2016 | Kenmore Washing Machines
Washer will not proceed to rinse cycle
Maytag leaks This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 14, 2013 | Maytag Neptune Washing Machines
Wash machine water issues
pull the hot water hose off at the faucet and machine and check for blockage in the hot water hose,clean or replace the hose sediment screens,then hook back up to water faucet and flush hose with hot water,then check water valve on machine for a screen and clean it as well before reconnecting hot water hose
Apr 07, 2013 | GE WSM2480DWW Unitized Spacemaker Washer...
Leaking from underneath the machine
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Dec 31, 2010 | Hotpoint VBSR3100D Top Load Washer
Water leaking when machine is off
you need a new water valve. it is located at the back left hand side under the main top(the piece the hot and cold water hoses hook on to)
Feb 08, 2010 | Whirlpool GHW9300 Duet Washer
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
Water flows in cold side of water valve and out hot side valve
It seems unlikely that something went wrong just from moving it unless it got banged up!
It sounds like you may have stripped the hot side.
I'm assuming the water is going in the cold side and out the hot side and out the back.
If this is so and you are happy with just cold water try this:
Go to a Plumbing Store and buy a cap for the leaking intake...if it still leaks you can try soldering the two together!
I hope this was helpful.
Good Luck!
Jan 20, 2009 | Maytag PAV2300 Top Load Washer
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Hooking my washing machine to the kitchen faucet
See that your hose does not have any clogging in the filter screens; connect to the cold. careful with the threadings; turn on faucet & check for any leaks........start washing. Will tell you later how to get a manual. Regarding hot water, your machine can heat it if it has provision.
Dec 19, 2007 | Washing Machines
GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Mar 01, 2007 | GE WHRE5260E Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
