Question about Philips HDRW720 DVD Recorder
Philips DVR model HDRW720/17 Display screen shows "Blocked"
The Display shows the words "Blocked" and system does not take take open/close tray command either from remote or from the set. Even the tuner does not come (TV shows no signal).
I have rest the machine to the factory defaults and run the system setup but the results are still the same.
Any ideas?
  • 4 Answers
Do you have a disc locked up inside? I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Posted on May 14, 2009
DVD Tray Will Not Come Out
Download updated software for free on Panasonic Website then take a Paper Clip or other small object and insert it in the small hole in front of the machine and manually open the Disk tray. The Updates should take care of the Problem !
Oct 13, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
My Philips HTS6500 does not read most DVDs. After
HTS 6500 1- OPEN TRAY 2-PRESS DISPLAY 3-ENTER 9.9.9.9.0. 4 CLOSE TRAY. SHOULD WORK .
Sep 14, 2009 | Philips HTS-6500/37 System
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
Dvd tray wont open or close
@PrimePub : Have the tray replaced by manufacturer or ask manufacturer to ship one to you.
@at_viper : If still under warranty (i think so if only 3 months old) just contact your vendor about it.
Jan 13, 2009 | Philips HTS3450 System
PHILIPS DVDR 75/17 error code C003 TRAY BLOCKED
jim, try to open the tray manually open the cover rotate the motor or the belt manually.
Dec 13, 2008 | Philips DVDR755/17 Burner
Philips DVDR3440H Our DVD recorder is playing up, insofar as the disc tray won't open. Each time I press the OPEN/CLOSE button on the front of the machine, the LED says OPEN and then BLOCKED. This then...
Disc loading mechanism fault. Might be of a broken gear wheel or a drive belt. In rare cases, the mechanism replacement should be done. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 08, 2017 | Philips Televison & Video
How to make philips HTS3565 region free. Any help will be appreciated. Thanks.!
icon_minipost.gifRegion code hack posted by videohelp4k1ng, July 27 2008:
Hack for HTS3050 also worked with my HTS3565D.
Open the tray. Press 99990 on the remote.
Region 0 will appear briefly on the left of the screen.
icon_minipost.gifRegion code hack posted by rocky631689, August 01 2008:
Also works on my Philips HTS3568DW/75
THANK YOU!!!!!!!
icon_minipost.gifRegion code hack posted by mikoyan, August 05 2008:
I´ve just applied to my HTS3565D/37 and it worked great. Do not expect it to show anything in the display, though. You open the tray, click the sequence in the remote and... Done!
Sep 03, 2008 | Philips HTS3500S System
Tray confused
I have an LG DVD player and recorder model # RC7423W and i have a similar problem, when i open up the disk tray it displays open and the tray opens for 2 seconds only and then closes. when i press the open/close button to open it again it opens and never closes back with a "Disc Error" on display until i close it manually by pushing it back inside.
I cleaned it from dust many times and tried to reset it but no reset button. i just tried to unplug the wire and plug it back.
let me know if there is a way that i can reset the hardware or a solution to my problem. my system is around one year old
Oct 22, 2007 | LG DR787T DVD Recorder
Tray is not opening
To open the tray this is not a perfect fix, but it will allow to use it. After the unit is powered on: 1)Hit the "Open/Close" button 2)Wait a while (you will get the timing down with practice) 3)Tap gently, yet briskly with fingertips at area in the attached pic, that the red arrow points to I think the problem is that the tray becomes unbalanced somehow. Because when a DVD is in, the drive opens fine, only when there is no disc do you have to tap on the unit.
Aug 13, 2007 | Philips DVP642 DVD Player
Philips HDRW720 DVD Recorder Logo
545 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
