Question about LG Studioworks 563N 15" CRT Monitor
Picture squeezed horizontally
Hi, The image on the screen is is squeezed horizontally about 2 inches from the top and bottom. Can someone please help me out with this? The picture is otherwise stable. Thanks, Sincerely, Balu
We have right click on desktop <properties<settings <apply ok
Posted on Mar 31, 2008
Samsung tv model un50eh5000v Having horizontal blurring and repetitive images from 8 inches from the top to the bottom of the screen. Top is clear. All inputs and stations.
It sounds like you have a defective panel. It will be cheaper for you to replace the set. Hopefully the place that you purchased the boards from have a good return policy.
May 11, 2016 | Samsung Televison & Video
Picture on TV ''squeezed'' to center of screen horizontally
Check the horizontal trafo output voltage,the capacitors and the power supply voltage (135-155V dif.the tube diameter).
Aug 14, 2009 | Panasonic Televison & Video
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
The horizontal on the screen has moved i have a 2
i have same problem it happens with my hdmi and component port.
did you ever find out what the problem was?
Apr 07, 2009 | Sharp Televison & Video
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
19" hansol 920p monitor
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Hansol Multitech 920p 19" CRT Monitor
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Sep 19, 2007 | Emerson EWF2704 TV
Full Picture Display
It's definitely not convergence. Sounds like more of a problem in the horizontal section.
Dec 19, 2006 | Panasonic PT-61HX40 61" Rear Projection...
Video is "Squeezed" and "Choppy"
you have a problem in your vertical circuit i would recomend taking it to your local shop rca's can be real tricky to fix.
May 30, 2006 | RCA 27F530T 27" TV
LG Studioworks 563N 15" CRT Monitor Logo
334 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
