Question about Lexmark Office Equipment & Supplies
PROBLEM WITH SETUP OF MFC 5495 FAX & ANSWERING MACHINE
  • 318 Answers
Do you want to setup the answering machine with the faxmachine?
Posted on Oct 31, 2008
How can I set up my answering machine with my hp 2140 fax
Use the fax setup wizard from the HP toolbox , when it asks if you have an answering machine connected to the fax line say yes. Or setup a distinctive ring from you phone company and set the fax machine to answer double rings only. Use fax setup wizard to do this as well.
Jun 14, 2011 | HEWLETT-PACKARD HP 2140 Fax
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
My fax machine MFC7420 can not recieve any faxes but I can fax out? Please help ASAP. Erica 514-940-3645
There could be many reasons why your MFC won't receive faxes. 1) MFC may not be set to answer incoming calls, 2) Call is answered by voicemail (or answering machine), before MFC is programmed to answer, 3) Incoming ring line voltage is insufficient for MFC to detect. Check the first 2, as those will be simplest. You can check the 3rd, but you'll need another fax machine to do so (if it receives, then your MFC should receive). Let me know what you find out.
Aug 13, 2009 | Office Equipment & Supplies
On my MFC-240C I can no longer receive faxes. We
Ensure that the new telephone is plug correctly into the fax machine the. Phone line belong in the "line" socket. Telephone/answering machine belong in the phone socket. Does the telephoe answering machine work ok without the fax. does fax work with out answering machine
Aug 12, 2009 | Brother Office Equipment & Supplies
Won't fax
You have to get your answering machine and your fax to play nice. Read the instructions for both. I think I have my answering machine to pickup at three rings, and the fax to pick up at five. Don't have the fax answer first. Don't have both machines answering at the same number of rings.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
After 4 rings our fax machine picks up automatically,
Your owner's manual will tell you how to program the MFC. There is one on the install disk, too. If necessary, you can get one by Googling your machine.
Mar 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother Multi function centre with fax, MFC 885CW we have the setting on F/T, it answers a fax after 2 rings, if a call coming in it keeps ringing, but on callers end it keeps beeping fax noises, callers...
I had the same problem using my Brother MFC 8460N fax on the same line as my regular telephone, which has an answering machine.
There was nothing wrong with my equipment. It was a set-up issue. I solved it as follows, and maybe this will be helpful to you:
Here's what I did, step by step:
1. Put your MFC and your telephone near each other, and within reach of a phone wall jack.
2. Go to the fax machine. Take the telephone line with the clip on the end of it that comes out of the fax machine. Put that into the telephone wall jack.
3. Go to the answering machine. Take its telephone line with the clip on the end of it and put that into the BACK OF THE FAX MACHINE. The port on the back of my fax machine says something like EXT TAD which means external telephone answering device.
4. Go back to the fax machine. You'll now need to play around with the menu options for the fax. My Brother MFC shows this stuff in a little screen on the front. Try and find the Fax Setup options. Next, try and find the Fax Receive options. If you do, select something like External TAD fax receive mode. Do not give up, you're almost done.
5. Next, set ring numbers on both devices, the fax machine and the answering machine. I set both devices' ring numbers to 4. I don't know if these are the optimal settings, or what happens if you set them at different ring numbers. I only know that a "4 and 4" setting works for me, and am not inclined to mess with it.
6. Final detail: the setup should be transparent to a voice caller. Someone who is sending a fax, though, might be a little confused IF, like me, they lean over to listen to their fax machine dial and screech, just to be sure it's working. Such a person may faintly hear my outgoing answering machine message before they heard my fax machine's screech kick in. They might think that they had a wrong number, cancel the fax, try again, call me with questions, etc., etc. So I changed my outgoing message to something like: 'You have reached xxx xxx xxxx. To leave a voice msg, please wait for the tone. To send a fax, please continue the transmission and it will be printed. Thank you!'
That's it. Hope this was helpful.
Best,
Wilbere
Check out my listings on http://stores.ebay.com/WILBERE
Aug 07, 2008 | Brother Office Equipment & Supplies
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
