Question about Baby Lock Esante
Automatic thread cutter not working
When thread cutting button pushed you hear a ping, but it does not cut. I cleaned out all the lint, the cutters themselves work when tried manually but some connection not sparking the automatic action. Thanks for your help.
SOURCE: Thread cutter
I had the same problem with my Ellegeo. It came with an extra bobbin case, the black part the comes out of the race that the bobbin sits in, and I used the new one. Worked like a charm and I haven't had a problem since. Good luck!
Posted on Sep 11, 2008
SOURCE: Bobbin Thread cutter no longer works
I have a designer SE, I ran across this site and found it very helpful. This person is a retired machine repair person and has a wealth of knowlege. <> from what I understand the blade needs to be cleaned as part of the Maintenance, it also can be replaced.
Take a look at this site, perhaps it will help
Far Away Grandma
Posted on Oct 26, 2008
SOURCE: upper thread keeps breaking bobbin thread grtting cut on bobbin,
I have a esanta-model ESI-2. I am home-bound. I love making quilts. I know my machine needs some oil, could someone pleaSE TELL ME WHERE AND HOW TO OIL MY MACHINE? Thank you in Advance, Jude
Posted on Jun 12, 2009
  • 55 Answers
SOURCE: Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
Posted on Jul 27, 2009
  • 192 Answers
SOURCE: Elna 704 serger sews well but cutter won't cut.
Make sure that the blades are being held firmly together. I have seen the knob used to lower the moving blade come loose and releases much of the pressure intended to hold the blades together.  If so, the set screws on knob have come loose.
Posted on Sep 06, 2009
How do I fix automatic thread cutter on the brother PC 420?
I am not sure what to do about it. Did you try clean the shuttle real well? If that does not work, call Brother!
Oct 13, 2014 | Brother PC-420
Automatic thread cutter.bobbin thread does not feed to the top.
when you stop sewing where is the arm located ,up or down ..that will make a world of difference
Jan 06, 2014 | Elna 7200 Computerized Sewing Machine
I have a Pfaff grand Quilter and my top thread is not catching the bobbin thread. When it does the stitches skips. Can anyone help!?
If you have changed the needle and rethreaded the machine, then take apart your bobbin and make certain there are no small pieces of thread or lint in it. Check your tension. Do you have an automatic thread cutter? I had the same problem and it was because my automatic thread cutter was cutting the thread too short. Some how the cutter had gotten bent...I could not tell it, but it was.I put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
Jul 15, 2011 | Sewing Machines
I replaced the thread in my bobbin the same way i always do but i guess i did something wrong or by replacing it just made my problem stand out but now every time i go to sew, the top string gets cut on a...
That is your thread cutter. Depending on what machine you have, whether it is automatic thread cutter on an arm or just a manual one. If it is automatic, pop the cover off on the left top of machine next to the bobbin area. The arm should be seen there. It moves like an elbow. Push your thread cutter (scissor button) and watch how it works to see if it has come off the post. If you don't have automatic thread cutter, perhaps the thread cutter is not pushed all the way back in its place. The thread cutter looks like a triangular piece of flat razor. It could be sticking out too far or perhaps bent. I have fixed mine before, but be careful.
Feb 05, 2011 | Husqvarna Sewing Machines
The selective thread cutter not cutting thread.
You need a new blade in the cutter. It is a simple repair job, but needs to go to the repairman for it to be done.
Feb 28, 2010 | Husqvarna Designer I
My cutter doesnt work
Remove the plastic needle plate cover by sliding it towards you and clean all of the lint out with your provided brush. Small amounts of lint, fabric, and thread accumulate over time in there causing it to stop cutting...happened to me already. You should be cleaning this on a regular basis to keep feed dogs running good too. Hope this helps. =)
Dec 26, 2009 | Brother PC-420
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
Sewing Machines Logo
204 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
