Question about Whirlpool 30 in. RC8700 Electric Cooktop
Can fuse be blown?
Have Whirlpool ceramic cooktop Model RCC3024. NO power to it. No heat. Checked breakers. How do I check/change fuse?
  • reachj Oct 30, 2008
    ... P.S.: cooktop less than 2 years old. Worked great last night. Nothing this morning...
    Please help....
    but it has worked fine for last 2 years.. almost 2 years (my home was built new for me.. all new appliances) anyway it worked fine even last night. then this morning... poof... nothing... It is a built in oven separate from cooktop. I can lift the cooktop from the counter (granite) and look under it.... so i know i have proper wiring due to inspection when i moved into home... what could go wrong?
Yep... physically reset breaker... :-)
Posted on Oct 30, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Youl have to pukk out the unit and check the connection/installaiton. youll need to determine if you have proper voltage going to machine. ther if no fuse on the machine, more than like a power supply issue
  • Ron Coons
    Ron Coons Oct 30, 2008
    your power supply is on a 220-240 volt. its possilbe one of the power legs is no longer live or the connection has burnt off.you check breaker(did you physically turn off the "double breaker" and then flip back on possible it "half tripped" on you causing power issue
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
Front left burner will not heat up, all the rest are working fine
You either have a bad element or infinite switch. If you are handy you can do a few checks to determine which part is needed or if both parts are needed. On a failed element most of the time you can see a burn/break in the coil windings. You can check for continuity. On the infinite switch you can do a continuity check as well. If you are unsure of the repair I recommend change out both. The parts are affordable and you will have your cooktop up and running sooner.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0811053-00001.png
Please rate me "4 thumbs" if I was helpful.
Have a super day!
Dec 15, 2010 | Whirlpool RCC3024 Electric Cooktop
The cooktop indicator light on my Whirlpool range, model RF265LXTY, won't go off, all of the knobs are in the OFF position. The hot surface light is off.
most cook tops the light that maches the burner is on if sw is on . if light doesnot fo off replace that sw . if only one light for all burners you will have to fint the shorted one.. good luck mm ..
Dec 12, 2009 | Whirlpool RCC3024 Electric Cooktop
Whirlpool Flat cooktop burner not heating up
Try cleaning the knobs. I did the same thing you did (turning the circuit breaker off but that did not solve the problem.
My wife just tried turning the knobs and that seemed to work. It appears that one of the knobs may have been so sticky that the though it's in the OFF position it thinks it's still ON.
Jan 12, 2009 | Whirlpool RCC3024 Electric Cooktop
RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
These additional documents may be of help to you:
  1. exploded parts diagram;
  2. parts list.
Cheers.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
No heat. could fuse be blown
IT WOULD HAVE TO BE A POWER PROMBLEM FROM YOUR HOUSE sorry about caps lock on start at house breakers and and check wiring
Oct 30, 2008 | Whirlpool RCC3024 Electric Cooktop
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Whirlpool 30 in. RC8700 Electric Cooktop Logo
207 people viewed this question
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
