Bosch hot water issue does not heat the water
  • Anonymous Nov 19, 2008
    no water persure
  • The HVAC Guy
    The HVAC Guy May 11, 2010
    Is this a hot water heater you are referring to sir? is it gas or electric?
I had the 250 eq ( N.G.) for 3 years and have been dealing with bosch advanced tech service for the same amount of time. they sent me a new 2400 es( same thing, new model # ) last week and still having same problems. So i called them back. I'm on a well and come to find out after 3 years of dealing with them and after them sending me a new one, that they do not work well, on well systems,do to the varying water pressure. (no kidding!!!) After dumping tones of cash in to the darn thing they just sent me a mixing tank and mixing valve free of charge! I don't know if it will work do to the fact I have to install it yet. The best I can say is to call the tech dept at the 800 # on the back of your owners manaul and good luck seeing that no one knows how to service them!!!!!! PS You will need a manometer to measure the gas pressure at the valve.
Posted on Nov 22, 2008
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Cannot find pilot light on my bosch GWH635ESL, help!
Call Bosch
Gas Products Technical Support: 800-642-3111
That model number is only shown at one website, and that model number is not shown at Bosch.
Open following link for Bosch:
http://www.boschwaterheater.com/BoschHotWatercomHome/GasProducts/tabid/331/Default.aspx
Search of Bosch for that model number shows no result.
Some water heaters do not have a pilot light. Instead they use hot surface igniter rod that glows red hot
The igniter rod ignites the gas after solenoid valve opens and gas flows to combustion chamber.
The igniter rod and heat sensor have to be operational, and have to be positioned correctly for ignition to take place.
If igniter rod is not working, or if heat sensor does not detect flame, then gas solenoid valve shuts down and water heater does not heat water.
Sep 03, 2011 | Bosch Water Heaters AquaStar - Tankless...
What is an A7 code? Gas hot water heater
Before calling service technician, open following links for Bosch troubleshoot resources:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Error codes are start-point for troubleshoot.
A7 is temperature sensor fault.
This can be bad wiring, corroded wiring, failed sensor, very high temperatures due to other part failure.
Other cause can be water filter clogged, lime and scale inside heat exchanger, faucet aerators clogged, or combination of problems listed.
Each tankless manual across all manufacturers suggest maintenance schedule: clean water filter monthly, delime heat exchanger yearly, and yearly service of burner and other parts by trained service technician which can address cause of most error codes, and might solve some problems before they happen.
If tankless becomes chronic issue, solve problem yourself, same day, for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Jul 31, 2011 | Bosch & Tankless LP Hot Water Heater
Water comes into dishwasher cold. why???
Welcome to FixYa.
Have you insured the unit is connected to a hot water supply line ? The water will not heat until it start's to circulate and activates the "flow switch" in the Bosch dishwashers.
If it is connected to a hot water supply, try running the hot water at your sink taps before turning on the dishwasher. If you still do not have hot water, check your hot water heater or supply.
If it is indeed connected to a cold water supply it will work, just be prepared for very long wash cycles since the Bosch machines will heat the water at a rate of 2F per minute...it could take a long time to reach 155F.
Let me know what you find out and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch hot water service 16p burner shuts down
a tankleess water heater doen's have a piliot? but check the vent outside make sure nothing is blocking it, if it detects the exhaust thru the cold air intake it will shut off and over heat, other then that it would have to be the control board
Jun 05, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Running water in 2 sinks just to get hot water from a bosch
you can put in a circulatating pump that is controller with a timer and a thermostat so the when yo need heat water the most its readilly available and when you don't it's off, the only thinsg thing that you would have to do it tye in the supply and the return and then insulate the pipes.
Dec 26, 2008 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Dishwasher not drying - Bosch Integra SHU9952
Bosch generally drys through evaporation from hot water rinse. There is a common circuit board issue where a cold solder joint on the heater relay pops.The water does not heat sufficient to evaporate any longer. Consult your manual for self diagnosing trouble shooting codes or go to appliance aid.com.
If the board connection is the issue I have repaired several, however Bosch recommends replacement only and sometimes supplies the parts free.
Aug 14, 2008 | Bosch SHU5315UC Dishwasher
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
